Drilling Holes in Thermostat?
Old 01-10-2007, 06:07 AM
  #51
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
well thats good to hear......hey, what part# temp switch did you go with? I still need to get one and I want to to work with my 180 stat...
thanks
Old 01-13-2007, 06:23 PM
  #52
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Originally Posted by Stekman
Some people have it, others don't. My Camaro never had an issue like that. However, my Caprice does. Consider it a flaw of design in the conventional cooling system where coolant hits the block, then goes to the heads with already heated coolant.
I can watch my Caprice's gauge climb up to 220-230 before it will drop and I have a 180° thermostat in it.
I gave the Camaro a surge tank to alleviate those air bubbles, so we'll see how that turns out.
Does it dropping have anything to do with your fans coming on? Putting a lower temp thermostat in your car doesn't make your fans come on sooner. This may or may not be an issue at highway speeds, depending on how much flow you're getting through your radiator.
Old 01-15-2007, 04:03 PM
  #53
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I've seen european standard stats with a tiny 0.04 hole in them, so that's obviously just to let air pockets through. Air is very bad at transferring heat, and still-standing water takes time to heat, so getting rid of the air and getting the water moving will let the stat feel the real temp of the engine and open quickly instead of sitting in an isolated pocket of air and water thereby rising slower in temperature than the heads, opening too late, causing an overshoot in temp..
I wouldn't rely on a standard guage for accurate temperature indication btw..
Old 01-17-2007, 10:45 AM
  #54
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
I'll tell you what made me a believer. Ever notice that when you change the coolant and introduce air into the block the first time you start the engine the temp goes thru the roof for a minute and scares the hell out of you? And then you kill it real fast cause you think the thermostat aint gonna open? And you do this 2 or 3 times until the stat finally opens and lets the air and steam out. Been there done that dozens of times but NEVER on a car with a drilled thermostat.
Old 01-17-2007, 10:57 AM
  #55
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have one 1/8" hole in my 180 thermostat. I did it for the air pocket theory.
sheachopper
07-31-2019 11:27 AM
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
drumstixer
09-29-2015 03:02 PM
Quick Reply: Drilling Holes in Thermostat?
