Replacing A/C clutch cycle pressure switch
Old 11-07-2016, 03:01 PM
motleykent's Avatar
Car: 1987 Chevrolet Camaro Iroc-Z
Transmission: B&M 700R4
Hello,
I had my 1987 Camaro into the shop this summer as the A/C had stopped blowing cold air. The refrigerant had leaked out as there was a bad O-ring. The shop refilled the A/C and the technician also noted that the low pressure switch wasn't working. After some searching I was able to get a new switch but wanted to check with you guys to see if I need to take my car back to the shop to have the new switch installed or can I do this myself? This might be the least intelligent question I have ever asked on here, but I am not sure if the A/C system needs to be evacuated for this particular switch or not.
Thanks.
Old 11-07-2016, 03:10 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Replacing A/C clutch cycle pressure switch
Unscrew it, put new one in. There's a schrader valve on the port to prevent refrigerant from escaping.
Old 11-07-2016, 03:12 PM
motleykent's Avatar
Awesome, thanks. That is exactly what I was hoping for.
Old 04-04-2017, 12:12 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
Originally Posted by motleykent
Hello,
Thanks.
You don't happen to have that part# for that low pressure switch do you??
Old 04-13-2017, 10:55 AM
motleykent's Avatar
I went with the Four Seasons AC Clutch Switch, part number 36674
Old 04-13-2017, 12:22 PM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Thanks!!
