confirm this bad ecm
Old 10-13-2014, 09:02 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Taken on my moms 92z to get her rolling after sitting in a yard for 7 years. 350 tpi full exhaust with cats. Figured this is relevant.
After fixing multiple driveability issues I attempt to plug my MODIS to confirm sensors and other data looks OK to me. All I get is no communication. I checked all fuses. I checked to make sure I have good ground and 12v constant at the aldl connector. Nothing out of the ordinary.
Moms b/f added an aftermarket alarm and radio but I verified that shoddy wiring aside, it didn't interfere with the ecm.
The ecm was swapped at some time for an 89z24 ecm which is a '730 ecm.
The b/f isn't very auto savy, he's a part changer. Lol
Help!!!
Old 10-14-2014, 08:40 AM
L98_383_Stroker's Avatar
Re: confirm this bad ecm
What voltage do you see on pin M? That is the data pin. On 8192 baud cars, they typically set at +5V waiting for the scan tool to send a message.
Also, does shorting pins A&B get the ECM to flash codes? That might help to determine if the ECM is bad.
Old 10-14-2014, 02:50 PM
Car: 91 formula ws6
Transmission: 4l60E
I'll check that this evening. I did have a positive voltage less then 12v on pin m. I'll verify exact tho
Old 10-30-2014, 11:01 PM
Car: 91 formula ws6
Transmission: 4l60E
I only get code 12 flashed when jumped. Sorry for the late response. Taking work while I can so no time to go fiddle with the car often
Old 11-03-2014, 08:01 AM
If you are getting code 12, I would think your ECM is okay. I think the only way to troubleshoot your issue is to hook an oscilloscope to the ALDL line and see what is going on. Your scan tool should be sending a short message to the ECM requesting a data packet. If you don't see that message traffic, I would suspect the scan tool. Are there multiple ALDL connectors for the MODIS? Some ALDL cars have data on pin E and some have data on pin M. I don't know how the MODIS handles that. The cars with data on pin E are 160 baud and don't require the scan tool request message. Cars with the data on pin M are 8192 baud and require the message request.
Old 11-03-2014, 11:55 AM
Car: 91 formula ws6
Transmission: 4l60E
Yes each type of car has its own connector. Then you select the year. Are the pins on the 89 '730 ecms the same as 92 '730 ecms? Again, I didn't swap parts. I'm trying to procure the original ecm from the car since it was saved. I believe the original problem for the swap was vats issues. Lol. Damn lazy people
I'm familiar with the '165 ecm and the '411. I never messed with the '730.
Old 11-11-2014, 06:16 PM
Car: 91 formula ws6
Transmission: 4l60E
Found the problem, the pins in the aldl were loose. I hate threads that never post an answer or drop off so I figured I'd help out the next guy with the cause. Thanks for the ones who helped!
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
Blue419
09-10-2015 01:03 PM
Stryker412
09-07-2015 09:11 AM
willyjoejr
09-03-2015 09:26 AM
RyanJB
09-02-2015 01:27 PM
Quick Reply: confirm this bad ecm
