730 ecm or Holley 950 commander.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
355, AFR 195, xfi 224-230 112, HSR with full bolt ons. Is it worth changing to the Holley 950 ecm or keeping my "730" with an ostrich and tuner pro rt? If I was to change to the Holley what all is needed to make it run with the dash harness and 730 ecm harness?
Re: 730 ecm or Holley 950 commander.
I have a 950 and love it. The harness wasn't that hard to switch out on mine. The engine harness was separate from dash stuff except for a few wires. The 950 is pretty outdated though as far as auto tuning with the newer stuff. I did find a guy that has made an auto tuner for 950 for the fuel map though. It works pretty good. You will lose converter lockup with the 950 but there are other options to control it.
UltRoadWarrior9
04-28-2020 10:39 PM
