EGR question
EGR question
I am thinking of putting an non egr intake on my 89 TBI. If I set "Disable EGR if MAT < X" to some number like 350 degrees would this prevent a code? I am thinking this is the easiest way to convince the ECM not to turn on egr.
Thanks!
Thanks!
Re: EGR question
In $8D, there's a switch you can throw to disable the EGR diagnostic in addition to setting the enable values to something impossible. Not sure about the 8746 though...
Car: check
Engine: check
Transmission: check
Re: EGR question
There are two coolant entries that need to be set:
Since it is the inverse temperature setting them to 0 is 150* C.
RBob.
Code:
LD20C: FCB 177 ; 30c, coolant thres LD20D: FCB 165 ; 35c, coolant thres
RBob.
C2YT
08-22-2017 12:25 PM
hydrolic144
02-24-2016 01:06 PM
