730 segment addresses
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Anybody able to share rom/ram, I/o segment addresses?
I have basics but looking at other ROMs it seems like there's some space not addressed in the tune. Noticed SAUJP clears more NVRAM space than axxd. Haven't looked more into it. Figured I'd ask first. I don't know the physical sizes of the segments so I'm a bit blind.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: 730 segment addresses
Grab the file noted in the other thread.
Has most if not all you are seeking.
This is taken from that file.
Jp
Code:
;****** SEGMENT TABLE (AUJP) **************************************************** ; 0xCE64 ; SEG 0, MAKE A/D BARO FROM MAP (Is 0xCE5C in ANHT) ; 0xCEC5 ; SEG 1, DESCRETE & PWM OUTPUT ROUTINE (Is 0xCEBD in ANHT) ; 0xD129 ; SEG 2, OIL TEMP (Is 0xD121 in ANHT) ; 0xD278 ; SEG 3, LOG RAM TO I^2U (Is 0xD270 in ANHT) ; 0xD169 ; SEG 4, MISC 100 Msec ROUTINE (Is 0xD161 in ANHT) ; 0xD285 ; SEG 5, A/C, C/L, TEST OF FAN (Is 0xD27D in ANHT) ; 0xE4C0 ; SEG 6, LOG RAM TO CPU, COOLANT, A/D CON (Is 0xE4B8 in ANHT) ; 0xD514 ; SEG 7, LK UP COOL VAR'S (Is 0xD50C in ANHT) ; 0xD564 ; SEG 8, ESC LOW OCTANE SPK MOD LOGIC (Is 0xD55C in ANHT) ; 0xD5CE ; SEG 9, AIR MANAGMENT (Is 0xD5C6 in ANHT) ; 0xD6C9 ; SEG A, KNOCK, MAT IAC VAR'S, ETC... (Is 0xD6C1 in ANHT) ; 0xD81A ; SEG B, EGR (Is 0xD812 in ANHT) ; 0xD885 ; SEG C, CCP (Is 0xD87D in ANHT) ; 0xDA04 ; SEG D, DIAGNOSTICS (Is 0xD9FC in ANHT) ; 0xDE51 ; SEG E, BATT VDC, TCC, CARS, E LITE (Is 0xDE49 in ANHT) ; 0xE1CE ; SEG F, AIR/FUEL MAJOR (Is 0xE1C6 in ANHT) ;-----------------------------------------------------------------------
Engine: LB9
Axle/Gears: 3.08
Jp
Code:
