EBL Flash: Dual Bank Wideband ZT-2 + ZT-3?
Old 09-27-2016, 02:44 PM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
Hi TGO,
I'm in the market for a wideband o2 sensor kit to go with my EBL flash in an L98 87 GTA. I'm new to this (of course) and have spent a few hours reading up on different systems to learn what I can first. I haven't been able to nail down a good comparison or installation example, however, of a dual bank vs single bank o2 sensor setup. Zeitronix seems to have a good setup if you combine a ZT-2 and ZT-3 (one each side of the Y-pipe), but would someone be able to explain how the second sensor could be used with the EBL flash and how much of a benefit it would have compared to a single bank setup below the y-pipe connection?
Even though the ZT-2 will accept the ZT-3 as a secondary input for datalogging and other things, will the flash be able to use a two bank input (via 2 ADC inputs) and actively use them both for engine management? Likewise for the VE Learn capability.
Thanks!
Old 09-27-2016, 03:22 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: EBL Flash: Dual Bank Wideband ZT-2 + ZT-3?
If you are using batch fire ignition, why don't you use one wideband and two bungs. Compare the output on logs to see. You can't easily adjust it, so you're really looking for the leaner bank. Then use that bank to log until you change something to effect engine air flow.
Old 10-06-2016, 01:17 PM
Engine: L98 TPI
Definitely a thought. So with the batch fire approach TPI uses, it doesn't sound like there is really any benefit from being able to monitor data from both manifolds?
Old 10-06-2016, 01:30 PM
Engine: LB9
Axle/Gears: 3.08
To 99% it's pointless to always monitor both.
Old 10-07-2016, 06:26 PM
Engine: L98 TPI
ok, thanks
Old 10-11-2016, 10:48 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Since you can't tune any injector without affecting the other 7 I can see what you are getting at here, but wouldn't it still tell you the overall condition of one side vs the other? You may not be able to tweek the fuel on one bank but it would be a good diagnostic tool for finding out if something has gone wrong on "the other" side.
I have been considering a second wide band for these reasons. But getting to the bigger point here I am starting to feel like the batch fire method leaves a lot to be desired. With my Holley Stealth Ram intake, which is front fed, I always get leaner plug indications for the front 4 compared to the rear. In fact I have been tempted to go to a single plane intake but the more I think about it a sequential firing ecm may be a better use of resources. Then, WB on both side could be of real value.
Old 10-11-2016, 03:34 PM
Engine: L98 TPI
Based on the reading I've done since posting this and given the batch fire design of the TPI is more that 30 years old now (already?!), it seems like SFI is the best way to go if you have the time and resources to put into it. Dual bank widebands may actually be useful at that point for tuning, but realistically not all that useful before since you can't use the information the second bank would provide for tuning anyway.
The '411 ECU swaps on the board are good reads in themselves and aren't really all that expensive to do, by the looks of it (compared to an SFI engine swap, anyway). Just time consuming.
Old 10-12-2016, 01:13 AM
Engine: LB9
Axle/Gears: 3.08
Which is why I put in the "always" in the wording you quoted. Always monitoring is pointless, but diagnostics is one reason one is inclined to do so.
Old 10-12-2016, 09:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Search for "split BLMs", SFI isn't the answer.
RBob.
Old 10-12-2016, 01:15 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
RBob.
What do you mean? I searched as suggested but didn't really get it.
For my application, I can't seem to get even fuel distribution from front to rear (I don't know about bank to bank) and was wondering if SFI would help. Currently using EBL flash and would like to stay with it but had wondered if a 411 type ecm would give better control.
Old 10-12-2016, 01:26 PM
Engine: L98 TPI
Check out this link, it's a good read on what a split BLM is, what it's caused by and a possible solution:
Here's another, more exotic solution for a miniram (which apparently really has an issue with a split BLM):Explanation of what a BLM is:
"In a nutshell, the Block Learn Multiplier (BLM) is the long term fuel adjustment that the ECM "learns" to keep the air/fuel ratio within acceptable parameters. The Integrator is the same idea, only for short term adjustments. Basically, these two strategies are used to make adjustments and adaptations to the ever changing loads, atmospheric conditions, and fuel quality to keep the car's air/fuel ratio correct for driveability and emissions."
PS, thanks for the suggestion rbob. Just learned something new.
Old 10-12-2016, 01:36 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Thanks for that link. I understand the IAC function but don't exactly understand why it would affect the bank to bank blms. Does the stock intake have separate passages for the idle air? Or is there somethine else I am missing?
Still, I don't know if I have split blms or not. I have distribution issues from front to rear. Now if I could plumb idle air back to the rear group of ports that may help and something I have considered.
Old 10-12-2016, 01:40 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Wow, you must have added the other links while I was replying!
Very interesting info.
tmellott89
08-27-2016 02:59 PM
fastrs1891
South Central
03-19-2014 11:01 PM
freaky
03-06-2012 02:47 PM
pellmanm
47
10-13-2005 08:36 AM
Quick Reply: EBL Flash: Dual Bank Wideband ZT-2 + ZT-3?
