Fuel pump relay diagram...
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Ok guys, long story short, buddy installed painless harness wit the fuel pump relay into it and im obviously gettin rid of the harness since it controlls the whole tpi setup. anyway he left wires capped off on the driver side and i know thats where the relay goes, how do i run a relay to which wires? i got a tan/white wire, purple, red, another plain tan and one other wire but i forgot the color. any help is appreciated. thank you
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Fuel pump relay diagram...
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Top center of the diagram shows the fuel pump circuit wiring.
Hope this helps.
Lou
Hope this helps.
Lou
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
is this the same for a 86 IROC Z the tan/white would be the wire to splice into to connect my fuel pump relay for 94 lt1 swap right?
Car: 25th Anniversary Convertible Z28
Axle/Gears: Stock
thanks for the diagram. just bought my z28 and haven't got the book yet.
