Hei conversion to external coil.
Old 07-17-2012, 12:36 PM
Bhobbie's Avatar
Car: 1988 Camaro z28
Engine: 383 Stroker
Transmission: 4 Speed
I have a 1988 Camaro z28. It has a chevy 350 carbureted. It has the stock big GM hei distributor with the enternal coil. While also upgrading the electrical system I would like to convert the stock hei coil to take the MSD blaster 3 external coil. here are the things I have purchased.
1. New MSD Cap and Rotor(8416)-http://www.autozone.com/autozone/parts/MSD-Distributor-Cap/1988-Chevrolet-Camaro/_/N-ihrd4Z8gctb?itemIdentifier=688597_386109_0_
2. MSD EXTREME HEI EXTERNAL COIL ADAPTER-http://www.speedwaymotors.com/msd-extreme-hei-external-coil-adapter,9602.html
3. MSD 18" 8.5mm red male coil wire
4. AC Delco R45TS (8) spark plugs
5. MSD Ignition 8214 0.8 ohm Ballast Resistor
6. And finally the coil: MSD Blaster 3 with mounting bracket
7. MSD 8.5mm red spark plug wires
Now I have a few questions. Am i missing ANYTHING here at all to complete this experiment?
Do I NEED a new electronic module?
Is there a wiring diagram to help me wire the Ballast resistor and coil?
Linson
09-25-2021 07:55 PM
RedLeader289
05-28-2019 01:47 PM
school boy
10-22-2015 11:47 AM
skinny z
10-05-2015 06:23 PM
Damon
09-26-2015 04:29 PM
Quick Reply: Hei conversion to external coil.
