Power Window Relay/Fuse/Breaker???
Car: 1987 Camaro Iroc / 1970 Camaro Z28
I recently purchased an 87 iroc with power windows. Ive been snooping around and found a bunch of old alarm system boxes and wiring under the drivers dash footwell. ONe of the items found was a Voxbell box that is tied to the power window connectors coming from the power window switches in the center column. Could anyone help me identify the proper relay or breaker that should be plugged into this circuit? Heres a pic of the voxbell box plugged into the power window wiring.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Power Window Relay/Fuse/Breaker???
None of that is color coded properly to discern what is what. About all I can tell from the pics is they rerouted the IGN power lead to red for the alarm box. If you need a new GM style harness, PM me I can help. Are you wanting to eliminate that alarm box and put the window circuit back to stock?
Yes, the goal is to go back to stock. Im not sure what is affected with that wiring though. I unplugged the box and the car starts, drives fine but windows don't work. Is it a relay or breaker that should be on the end of each of those harnesses up under the driver footwell somewhere?
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
09-13-2015 09:07 PM
