Washed Engine: Won't Start
Old 02-18-2017, 12:24 PM
vincevs's Avatar
Car: 1982 Trans Am
Engine: 305 with a cam swap
I washed the engine bay of my 305 82 Trans Am, waited till the morning and just cranked it over. The old beater throttle is sticky so I shut her down to lubricate it up.
Now it won't start back up... won't even engage the starter or try and turn over. Battery is fully charged and all other 12V systems function properly.
Is is there a main relay somewhere that got wet under the hood? Maybe it tripped a fuse? Any other ideas?
Old 02-18-2017, 12:41 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Washed Engine: Won't Start
You should start by checking your battery connections your ground to the engine. This started lug has a power wire that runs to your fuse box and ignition switch from the ignition switch a purple wire If your battery connections are good you may have an issue with the purple wire at the starter itself.
Old 02-18-2017, 12:59 PM
vincevs's Avatar
Car: 1982 Trans Am
Turns out a hit a kill switch under the dash looking at the pedal... now to find a thread on fixing that problem. Thanks for the feedback!
