[GA] Siemens Deka 60 lb/hr injectors - barely used
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I have a set of Siemens Deka 60 lb/hr @ 43.5 psi fuel injectors that are 72 lb/hr at 58 psi. This set was flowmatched with the EV1 connector. They are the long style for the TPI, LT1, etc engines. They are lightly used with around 400-600 miles on them and only had 93 octane through them. I also have all data for them and can send you the data so that you can plug it in to your tune and be ready to go.
Asking $250 shipped.
Thanks!
Thanks!
thejimsterz28
09-15-2015 04:37 PM
