[TX] TPI setup
Engine: 5.7ltr
Transmission: 700r4 with shiftkit
Axle/Gears: LS 4.11
TPI setup
I have a TPI setup out of a 1988 Trans am 5.7 with a 700r4. The following is for sale:
I have a TPI intake setup for a Chevy/ Pontiac Trans am. This came off of a 5.7 ltr car with a 700r4 transmission. I am selling the following as a whole "kit":
Complete TPI intake with runners and fuel rails with injectors and throttle body unit
All sensors are either new or good used
MSD Blaster Coil with connectors
TPI Distributor slightly used, very good shape (bought new in Dec 2014)
cold air intake with K and N style air filter and new Mass Airflow sensor with pigtail.
Computer (ECM) with PROM
Engine wiring harness (wires will have to be spliced back together in spots) You can also get one new from Painless Wiring for under $500
Dash Harness - from firewall to ECM including VATS module.
I also have a VATS bypass that I can throw in for $40 that is not used. It comes with instructions and a fused power wire.
Unit is nice and I can send pics to interested parties. $300 for the complete setup minus the VATS bypass.
Text 940-867-0481
Text 940-867-0481
evilstuie
01-09-2020 08:29 PM
Sanjay
08-12-2015 03:41 PM
