[PA] Parting out an 1988 Trans Am GTA
I am parting out a 1988 Trams Am GTA hardtop I recently bought. It was originally a 350 TPI/auto car,
There is no motor or trans available, Rear is a Borg Warner 9 bolt posi disc brakes with 3.27 gears. Interior is tan and in very good condition including the dash pad. here is the list of what I have:
2) TPI harness $80
3) ECU $70
4) pair of barely used rear shocks $20
5) aftermarket 16" fan $30
6) like new ( stock) aluminum radiator $60
Located in Hatboro, Pa
2) TPI harness $80
3) ECU $70
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
Re: Parting out an 1988 Trans Am GTA
I need the connector that's on the hatch for the third brake light. I have the contacts on the panel on the car but for some reason I'm missing the piece that's on the hatch. Also need the hatch struts if they work and oddly enough I need the cap for the power steering pump. Just the cap, mine has some cheap aftermarket cap on it that rattles like hell.
Car: 1987 Trans AM
Darn, well what do you want for the struts?
89Zleeper
03-16-2016 06:55 PM
