L98 motor swap into 1970 Chevy C-20 4X4
Old 02-28-2009, 11:58 AM
Chevy Chasen's Avatar
I picked up a l98 motor and am going to swap it into my chevy. I have a couple questions.
I want to get rid of all the emisions on the motor since i dont need them any insight on how to plug or cap off wiring?
Also wiring harness with computer where would i get one as well as motor mounts.
My transmission is a 4 speed trany with Grany gear would i match the clutch up with the trany or the motor.
Any insight on the swap would be great. Im am going to do the swap in my garage and want to get all the parts i need before i start. Thanks
Chevy Chasen is offline
Old 02-28-2009, 06:37 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Well, we are a 3rd gen f-body Board. Rules say topics have to be related to 3rd gens. Having an engine out of one might qualify if the can be related to 3rd gens, but you're going the wrong direction for that.
But, a will answer the emissions questions (you still need O2 sensor if you're keeping the TPI system), and most any small block Chevy can be mounted to a Chevy V8 bellhousing. I'm afraid you're going to have to figure out the flywheel and clutch yourself (hint: 1-piece rear main seal and 168-tooth flywheel).
five7kid is offline
jhawkeye
05-25-2022 06:33 PM
xkingcodex
02-12-2020 07:43 PM
ezobens
08-19-2015 10:29 PM
TheExaminer
08-19-2015 10:07 PM
matthew911
08-12-2015 09:38 AM
Quick Reply: L98 motor swap into 1970 Chevy C-20 4X4
