walbro 255/Kirban FPR?
Old 05-19-2012, 03:31 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Ok so this is the deal... I installed a walbro 255 in tank pump in my 85 Iroc, and I have it ran to my Kirban FPR which is feeding my 383 HSR, Im using Holley HP efi. The problem is I cant get fuel to go through the kirban and into the rails. I actually heeled the regulator in my hand and primed the fuel pump with the gas line hooked up and nothing came out the other end. So I turned the adjuster screw both ways and nothing. At this point I just took the regulator apart hoping to find something blocking the passage, nope. Then I decided to put the Holley regulator on that came with my HSR and the same thing happened, nothing. Why am I getting fuel to the regulators but not fuel through them? After 13 hours of working on my car yesterday I never got it started, This build has been taking place for four years now and I really thought I was going to hear it run. Any help would be appreciated. Thanks.
Old 05-20-2012, 04:24 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: walbro 255/Kirban FPR?
Is it possible that Im not getting enough fuel pressure for the regulators to even work? I know I have some pressure because when I disconnect the fuel line from the regulator it squirts everywhere, I have to lay paper towel down and cuff the fittings untill it bleeds out. Nobody has any ideas to what is going on?
Old 05-21-2012, 06:37 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Someone please. Can anyone verify what the line pressure should be before the regulator using a walbro 255?
Old 05-21-2012, 11:18 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The same as after the regulator, if it's a return-type reg.
I have no idea what the pump is capable of producing if dead-headed. But, it should be well over 60 psi.
Lmancha96
09-25-2015 08:11 PM
R13_Braz
09-18-2015 05:00 PM
Nick McCardle
09-10-2015 08:36 PM
Strick1
09-04-2015 07:11 AM
Quick Reply: walbro 255/Kirban FPR?
