Which plugs/wires fit hooker 2055?
Old 10-15-2016, 05:26 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Next weekend I'm finally installing my hooker 2055 and need to know which plugs and wires to buy that will fit. When I searched for the answer it looked like Accel 276S was the way to go but it turns out they've been discontinued and now only have the Accel 276S-4. People on the forums have said the +4 plugs are a gimmicky waste of money. Should I get these anyways or is there a better option?
Old 10-15-2016, 07:42 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Which plugs/wires fit hooker 2055?
Fancy plugs are a gimmick, stick with the name brand standard design plugs. As for the spark plug wires I always run Ultima Select Wires - Spark Plug Wire Set 3235-03. I'm running Dougs Headers but they should work well with just about every header option out there; let's face it, headers are rough on plug wires and we will be replacing them every couple years.
Old 11-03-2016, 03:25 PM
rac
rac's Avatar
Car: Trans am 1987 ×2
Hi
I have 2055 headers on my gta, accel short plugs and some spark wires from summit whith 90° spark boots.
Fits perfekt and i dont think they will be burnt after a cuple of years.
Accel 276S and 276S-4 is the same plug but in a pack of 4 plugs!
You will ned coated headers or wrap them, or like i did heatprotect brake lines and cabling to starter.
Ministarter is recommoended! My original starter solenoid broke down after a few months, heatsheild did'nt helpe there..
dennisbernal91z
Fabrication
25
03-20-2017 08:42 AM
Yager90IROC
09-23-2016 03:12 PM
cheves
09-21-2016 05:50 PM
siuol
Car Audio
09-21-2016 08:38 AM
La Swope
09-16-2016 03:32 PM
Quick Reply: Which plugs/wires fit hooker 2055?
