Firebirds for Sale Post your Firebird for Sale.
1992 firebird mild built 350
Old 08-06-2014, 04:39 PM
rev.chuck's Avatar
350 4 bolt main block, eagle rotating assembly, kb pistons, 195cc heads, new lunati cam, push rods, roller hyd lifters, everything but the rotating assembly and pistons in this engine is new. gaskets bearings oil pump timing set. block started as a crate block so i can give you the numbers if youd like to verify that it is a 4 bolt main block.
edelbrock street master intake, i bought used
edelbrock 650 carb i just had rebuilt guy did an excellent job everywhere but cleaning the outside....
700r4 transmission with a shift kit ALSO fresh and the corvette 1-2 shift solenoid
original brackets to the 305 on the front minus the air pollution pump.
ac is gone but looks like it was taken off right. be expected to buy a condenser and all the lines if you want ac.
body has 130 xxx miles. and is in really good condition if you want my opinion. it has rust in the passenger wheel well. but it isnt alot. the underneath is clean some surface rust has flowmaster exhaust. the front fenders have been replaced and look terrible lol. but they are straight. like all these unibody cars there is damage to the front pinch weld from being jacked up wrong all those years. the rear hatch is an auto closing hatch and still functions nicely i do not have lock keys for the car
the interior is in great shape as well again my opinion. its dirty but should clean up nice the dashboard is not cracked, and the only real cloth damage ive seen is the passenger speaker grill which has 2 little tears. someone attempted to replace the headliner and did a poor job at it. the cloth and board are there but its all cut wrong and just hanging down. T tops dont leak far as i can tell ive washed it twice and only seen water leaking from the drivers side door window. the fuel gauge doesnt work unsure why. the oil pressure and temp gauge simply need the senders installed and hooked up. all other gauges work as should the check engine light is on of course and another light directly across i forget what it is though. should see it in the video.
located in illinois just east of st louis missouri in bethalto im asking 3500 obo. im interested in rail buggys on trade. prefer with title
clean title and ready to go. turn the key and drive away.
i think ive listed it all. 618 447 0483 i prefer text, blocked numbers dont even come through.
i also have a tpi intake setup that comes with the car, but you need the correct wire harness which i do not have.
Old 08-06-2014, 05:19 PM
rev.chuck's Avatar
Re: 1992 firebird mild built 350
https://www.youtube.com/watch?v=aZu9...ature=youtu.be
Old 08-08-2014, 06:18 PM
rev.chuck's Avatar
OBO
Old 08-09-2014, 07:18 PM
rev.chuck's Avatar
Old 10-12-2014, 11:16 AM
MintWS6FORMULA's Avatar
Location: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
To be honest, that's too much. Mint condition 3rd gen's are difficult in getting that. Couldn't help but notice the replacement parts (fenders which scream past collision damage), missing parts (no coolant cap etc), and dash warning lights that stay on all the time.
Vintageracer
01-10-2020 05:33 PM
camaro11j
09-19-2018 08:49 AM
AmorgetRS
Convertibles
08-31-2015 11:55 AM
pigpete
Exterior Parts Wanted
08-15-2015 07:56 AM
Quick Reply: 1992 firebird mild built 350
