1991 1LE - LB9/T-5 car
#51
Re: 1991 1LE - LB9/T-5 car
It is a totally different system under the dash as well but the hole in the firewall is the same. In the older cars with the white gauges the dashboard is even different. You have the same dash as a A/C equipped car. I wonder if you have the big vents in the foot wells.
#53
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1) the TPI sticker is one of those blasted things that had no exact spot where it was put... there was probably a specification, but like the birds on the sail panel of the firebirds or the Formula decals on the doors, they kind of put them willie-nillie in a general area and called it a day.
2) The pealing paint problem was an industry problem at the time. what happened was they started using a sealer to seal the cars, then they painted the car. The sealer worked great for sealing, but was not UV stable. since Blues, whites, silvers, grays, use less pigment than Yellows and Reds the UV light was not blocked well enough then attacked the sealer, then it started to flake off. Of course if they put a UV blocker in the clear coat or color coat it would have prevented the problem, or just used a primer either would have prevented having to repaint so many cars...
It is kind of counter intuitive as it would have been thought that the Blues, whites, grays or whatever paint had a blue hue would have reflected more of the UV than Reds or yellows but apparently they don't.
John
John
#54
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
I never did get around to taking those pictures. It's a Polar Vortex outside ya know.
#55
#57
#59
does that also mean that the world isn't flat?! LOL!
#60
#61
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
mechanic58 - did you ever conjure up pics of the footwells to see if the vents are there? I have a 1991 C41 RS and I'm wondering if the car is supposed to have them or not.
#62
Car: 1991 Z28 1LE
Engine: LB9 305
Nope, sorry. I never got around to it before I sold the car.
Linson
08-21-2015 02:12 PM
