Where have you found your build sheet?
Where have you guys found the build sheets in the cars? I've seen two different styles - one with the small text/codes & all of the options which was usually on the floor when it arrived at the dealership (& thrown out in the dealer prep) and the other with the large font letter codes that's often buried in the car someplace.
So where have you found yours & was your car a Norwood or Van Nuys build?
Re: Where have you found your build sheet?
I have found 2. Both cars are 1982 and Van Nuys. 82 Trans Am found on drivers side front, 82 base Firebird found on passenger side front. Interestingly, both cars were April 82 builds but different weeks.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
I've had a bunch of third gens now, and have only been lucky enough to find one build sheet. It was in the bottom seat cushion of the driver's seat and was in a bunch of little pieces by the time I was able to get it out. Had to piece it all back together to read it. Car is an '84 Z-28, I'll have to look again to see where it was built.
Community Administrator
There was multiple sheets.
This is what is often referred to as the build sheet. It contains all RPO codes for the vehicle as well as dealership information.
This is what some call the trim sheet while some refer to it as the build sheet. This sheet has less information than the build sheet shown above as this sheet doesn't have all RPO codes for the vehicle or dealership information. There was more than one of these sheets for the different assemblies.
This is a assembly line sheet on the last 1992 camaro that Leonard owns. If I recall correctly, there may have been more than one of these but I think he said a worker took one of them.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Build sheet for my 1987 Trans Am was under the carpet under the driver's side rear seat.
edit: Norwood car
edit: Norwood car
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My 87 Formula (Norwood) build sheet was passenger side under the carpet about where the catalytic convertor is.
Car: 88GTA
Engine: 5.7TPI
I always had a question regarding build sheets/trim sheets. And I know there is no answer, but I wonder why there were no "standards" or control measures in place for the placement of these? They could of put these in the packet you recieve from the dealer when you purchase the car.
I never got anything in my packet. I need to look under my carpet some day. I know its a Van Nuys car (88) and I bought it in Valencia Ca. about 10 miles from the plant.
Just curious.
Just curious.
Transmission: 5-Speed Manual
I Don't Think There Were Any "Standards",Guess It Depended On What Worker Was On The Assembly Line When The Car Was Built,Some Left Them Behind ,Some Didn't,That's Why Some Cars Have Them,Some Don't.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I found the large font sheet behind the drivers door panel on my 92 camaro. Car was built in Van Nuys I think.
Not a thirdgen, but my dad found the build sheet for his 67 Corvette stuck to the top of the gas tank when he dropped it earlier this year while starting the restoration process. Surprisingly, it was still perfectly readable after 47 years!
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
1984 Trans Am : under the carpet on the passenger side of the transmission tunnel
1989 Firebird : found the trim sheet under the carpet in the deeper part of the cargo area.
In both cases, I couldn't remove them, they were stuck to the floor.
Car: 88GTA
Engine: 5.7TPI
So from what I been reading, there must of been some guy "flinging" the sheet into the designated car and where it landed, it stayed and got covered up by whatever??
And when was the sheet put in the car...beginning....middle... end of the line?
Bob there were likely several sheets involved in the assembly process, one likely with the mechanical sub-assembly, 1 likely with the electronics (dash) and one with/in the body.
Unfortunately I think the carpet has been changed in mine so the odds of finding one there are slim, but I'll be looking anyways.
Here's a picture showing sheets taped to 1st gen drive line assemblies.
It is because the build sheets were used by the assembly plant and not intended for owners. At a Norwood meet, I recall one of the guys saying the assembly workers would trash those documents but that it didn't always happen.
Just curious.
Just curious.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I think they played,Hide & Seek with those docs.
It's totally random. It was easier to hide it in the car than walk to the bin.
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
As with kymmee, the build sheet for my 82 pace car was tucked safe and sound under the passenger seat. I have not pulled the carpet to see if anything is under there, but so far that is the only major documentation I have found in my car. I think I found a piece of paper from the IP cluster test (dot matrix printout) with a bunch of "OK"s listed when I removed the dash.
Cross-posting from my car's thread:
Dropped a camera lens cap under the seat and found this... pretty sure this is an assembly sheet and not a build sheet, but its condition leads me to believe there's a good chance the build sheet has survived if it is hidden in the car. I left this sheet in the car for now.
That stinks...
On the early cars, the sheet between the seat foam and springs will be the complete build sheet. On later cars it'll only cover some of the interior trim. Personally, I wouldn't bother removing the seat sheet on a 91-92, there shouldn't be anything on the sheet that isn't extremely obvious.
I've lost count of how many interiors I've pulled out of thirdgens. I've yet to find anything beyond the seat sheet. The conclusion I have to draw is that the buildsheet more often than not, was never left in the car. Or that it was left someplace so obvious that it was trashed when the car was cleaned up.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I found mine in the cargo area under the carpet. Unfortunately through Out the years it must have gotten damp, and is stuck to the floor. Have yet to find a way to remove it without potentially damaging it. I would love a solution to getting it out if anyone has any?
Engine: LB9 305
Transmission: AT
On my '79 Y84 "Bandit " Trans Am, I found one under a rear seat carpet and another on top of the fuel tank. Both in nice shape. (Van Nuys build)
I found one in my 87 Formula... it was a Norwood car, not sure if that makes a difference...
I would have preferred one in my 89 350 convertible or one of the LB9/MM5 cars, but not so far...
John
John
always thought it was weird how they would just cover it up under the carpet without any care in the world. I just couldn't see myself doing that if I was on the assembly line back in the day. I most likely would have just thrown them away and made all the future owners very upset that it wasn't there when they ripped their carpets out lol
Think of it this way Tyler - there are hundreds of cars going by during your shift. You have a mindless (usually) repetitive task to complete in a limited amount of time, all while talking to the co-workers around you about the game last night, your girlfriend, a hangover, where you are going when you get out. You figure out the best way to perform it to your ability with the least amount of work. If you have to bend over 1 extra time to pick it up then walk 8 steps & back to throw it away on every car - you're greatly increasing your work load.
They were left where they sat - and anything else that was laying there got left there too.
Engine: 4++,350 & 305 CIs
I have the one for my JY ttop 305 5speed. found it in the folder of paper work right along the dealer receipt for SLP parts install.
I have build sheets for several of my 2nd gen cars, but they had already been removed by the previous owners & put in safe keeping before I bought the cars. I have never found one on my own yet. I thought my 87 & 89 third gens would have them somewhere because I know the history of the cars from new. The owners before me would never have taken the cars apart (at least I don't think so anyway) I looked under the front & rear seats, rear hatch carpet area & found nothing. I didn't remove the door panels or the entire carpet, but I figure if they aren't in the normal spots they probably aren't in the car.
I also have an 80 T/A that I bought from the original owner who I asked about the build sheet & she had no idea there was something like that in the car. Haven't found that one either, but have not attempted to remove the entire interior to look further than the usual places. The 80 is a pace car replica, so that build sheet would be identical to the other 5699 of them
I've got back the car I ordered new - that's exciting enough for me. For paper I've got every stitch of documentation from the first two years of ownership from the original ordering worksheet to the service replacement invoice for the heads & engine. It was a let-down, but a minor one in the scheme of things.
I think they would leave the sheets in the cars when the trash can got full...
There Was No SOP For These Sheets To Be Left In The Car,Was Just Dependent On Who Happened To Working On The Assembly Line That Day,Some Line Workings Tossed Them In The Trash Others Left Them In The Car.
#42
Both of my 1982's were found under the front seats. Carmine LG4 under the drivers side. Z-50 LU5 was under the passenger side, and included a bonus-a ladies Bulova watch was entangled up in the wiring Harness. I found it when I serviced the power antenna motor 25 years ago. The gold kind of stood out. Both LA built.
On the 87 I got the build sheet from the first owner of the car. Norwood build.
#43
When did these sheets come into existence with GM? early 70's?
