Need Help can't remove seat bolts
Old 09-14-2015, 07:23 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Ok so I was changing the interior color. Once I got to the driver seat I had to cut the carpet our around the track. The track was rusted and the brackets that held the seat to the floor where broken of the track and stuck to the floor boards. I was able to get the track out but now the nuts are stuck to the floor and don't know how to get them out. I have been spraying pb penetrating lube for the past 5 day and tried to remove them with vice grip plyers and nothing. Don't know what to do next without damaging the mounting bolts or floor. Any help would be appreciated
Old 09-14-2015, 07:31 PM
Engine: 350 carb
Re: Need Help can't remove seat bolts
Old 09-14-2015, 07:41 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Heat it with a propane torch. Beware of the carpet and brake and fuel lines underneath. PB Blaster is good.
Old 09-14-2015, 09:38 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
and if you didn't ruin the nuts with the v-grips use a breaker bar, something that gives you some leverage.
Old 09-18-2015, 04:05 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Use a Dremel with a cutting disk to almost cut to the bolt. Be careful not to go too far or you will damage the threads. Then use a chisel and hammer to break the nut free. One medium hard hit should do it.
Old 09-18-2015, 04:16 PM
Engine: 350 carb
Thanks for the advice
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
Eric-86sc
04-03-2016 03:52 PM
1992 Trans Am
08-08-2015 08:16 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Need Help can't remove seat bolts
