'92 Trans Am trip odometer reset issue
Transmission: Pro-built 700R4
I'm having an issue with the odometer and trip odometer reset on my '92 Trans Am. When I press the reset on the trip odometer, the trip and regular odometer stop working. It will start working again eventually, but not right away. I drive about seven miles from home to work, and I didn't notice until my return trip home. The next day it worked fine and has seemed to work fine since, but I haven't pushed it again.
I removed the speedometer and opened it all up. Everything looks fine. I don't see any broken gears or wiring. the levers look like they are all functioning properly. When I press the reset, I don't see anything loose or malfunctioning.
I have another speedo that I can swap in, but it has an additional 10,000 miles I'd rather not have on my odo if possible.
Just wondering if anyone else had a similar issues or has any ideas how to fix it.
Engine: 4++,350 & 305 CIs
Re: '92 Trans Am trip odometer reset issue
A few of mine have the same issue, I have taken the **** off the reset button and removed the black plastic sleeve, it helped a little bit. It all gets in a bit of a bind so I normally just deal with it.
My guess is that you'll be replacing the speedo gear in the odometer soon as well.
https://www.thirdgen.org/forums/inte...roken-but.html
I checked the speedo gear when I pulled everything out. It looks fine. No cracking or wearing at all really. Is in there pretty solid as well. No abnormal movement at all.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Maybe the lever doesn't come all the way back up. Try spraying some thin lubricant on the ends of the wheels and the reset lever pivot points. I took a cluster apart and noticed that the grease was EXTREMELY thick at this point and all the wheels were hard to turn
I looked at mine and all the gears were good except that 1 goofy gear that had turned to goo on the metal shaft. It was hard to see the broken teeth with the electric motor in the way.
