[For Sale] Ls swap harness by pocket never used for 6spd
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: Ls swap harness by pocket never used for 6spd
Sorry to hear about your project. Just to help out this harness fit any 90-92 Fbody. I will repin the harness to fit an 85-89 EFI car to help any potential buyer
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
can it be switched for auto
Yes it is. It was built by a member on here Pocket. He has multiple wiring threads and will build new swap harnesses for people. I didn't feel good about doing it myself either so that's why I had him build it.
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Hmm ok I am interested. I have to wait until after the holidays though for the cash. If u still have it , I'll take it.
Car: 91 Firebird
Engine: 6.0
where did you plan on mounting the PCM?
Where are the relays mounted?
I'm interested in swapping out my homemade harness for one of a more professional caliber
Pcm was to be mounted in factory location under the dash. As for relays I'm not sure since I never installed it or laid it out in the car. It's a very nicely built harness. Pocket does a great job.
Car: 92 Firebird
Full specs:
Car, make, model, year:
91 Camaro RS
Original engine type:
Original trans type:
Auto
Year of PCM being used:
99-02
PCM location:
Stock 3rd gen
PCM routing
Stock 3rd gen behind the fender
Trans type:
T56
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6 EV1
MAF type:
Fbody 3 wire
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Single
Battery location:
Drivers side
Relay center location:
Stock near booster
Coils:
Stock coil location
Hit me up if you are interested in this harness but want something minor changed like year, trans type or dual fans or want a new one built to specs
91 Camaro RS
Auto
99-02
PCM location:
Stock 3rd gen
PCM routing
Trans type:
T56
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6 EV1
MAF type:
Fbody 3 wire
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Single
Battery location:
Drivers side
Stock near booster
Coils:
Stock coil location
Car: 1991 Z28
Engine: 6.0, forged internals, 243, EPS cam
Hey pocket, can you add another fan? I'm going to run the stock dual fan set up on a 1992 Z28.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
sent out a pm last friday regarding possible changed that I would need. Would you want this shipped to your location, or could you just sent out additional pigtail/some wire?
Full specs:
91 Camaro RS
Auto
99-02
PCM location:
Stock 3rd gen
PCM routing
Trans type:
T56
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6 EV1
MAF type:
Fbody 3 wire
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Single
Battery location:
Drivers side
Stock near booster
Coils:
Stock coil location
91 Camaro RS
Auto
99-02
PCM location:
Stock 3rd gen
PCM routing
Trans type:
T56
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6 EV1
MAF type:
Fbody 3 wire
AC:
4th gen low mount
Coolant gauge:
98 3 wire CTS
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Number of fans:
Single
Battery location:
Drivers side
Stock near booster
Coils:
Stock coil location
92rsvortec350
02-22-2016 09:32 PM
gunznrosez87
10-14-2015 11:56 PM
509 camaro fan
10-11-2015 01:52 AM
