LT1 Wiring for dummies
#153
Re: LT1 Wiring for dummies
but hooking my guadges up im gona have to look at this form to see what goes where. but when i have those hooked up shouldnt my speedo and RPM work just fine?
#154
ahh ok. when i get a harness im gona pull one, because ill be able to label where everything goes as it comes out, i feel itll be alot easier for me.
but hooking my gauges up im gona have to look at this form to see what goes where. but when i have those hooked up shouldnt my speedo and RPM work just fine?
With a T56 a converter is needed to convert the speedo signal into something the gauge can handle.
Its all there, most of it in this thread.
#155
okay thanks. all i really wanted was to clarrify that all i really needed was the engine, computer, and wiring harness. thanks.
#157
Car: 85' iroc-z
Engine: 98 LT1, if all goes well
where can i find a "plug and play" wiring harness to put 95 LT1 in my 85 iroc? have the engine, tranny, computer and harness with the motor i bought.
#158
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I tryed to build my own but now I am going to sent both out the c 207 from the 86 and the 94 lt1 engine harness and have some one who know has to put them together for around $400
#162
what the price of the painless wire harness ??that what I have in my 55 chevy paid like $150 about ten year ago but the Lt1 Painless wire harness I think its like $850.00 which seem steep what is the price for a Painless Lt1 wire harnes my plan was to have AC in my 86 IROC Z let know what you find out thanks
#163
what did you for the painless wire harnes from where did you get your ?thanks
#164
I found the painless wire #60502 at Summit for $686 plus shipping that about the going price and still steep same at Jegs another place wanted ( $989.99
#167
your right $686 for a painless 60502 wire harness is NUTs gone are they days when HOT RODDING didn't cost an arm and a leg there also a place that called Currant they want's $619 for there harnes still too high
#168
Car: 1992 camaro
Axle/Gears: 3:73
You all should trying to pm Pocket he sells and makes harness for the LT1 swap ALOT cheaper than the painless. It's really not that hard if you have both harness.
#170
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
If by cheaper you mean double, sure
Your '55 would have used a generic X circuit harness centered around the fuseblock. Basic tail lights, headlights, carb distributor etc. EFI harnesses are more expensive because they use about 4x the amount of wire (copper is expensive) and 20x the connectors ($8-18 ea adds up). Dont forget, each companies definition of "plug and play" is different. To do a LTx/LSx swap in something like your '55, you'd need the basic harness first, then their "P&P" piece. For a 3rd gen you'll still have to use some sort of stock engine harness to get the basic power, IGN, gauges, fuses, relays etc connected. You cant simply use a painless harness out of the box and expect anything to happen
What is P102? Take a pic
#172
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
ok guys im really in need of somehelp, every were i read the diagrams cover up 95 does anyone have one for a 96 z28 lt1? or is it thet same as the 93-95?
i have spent alot of time reading through the form and over and over again through the stickys, but hot damn im confussed...lol
anyone with some help will be great.
#173
Car: 92 Firebird
http://www.lt1swap.com/wiringharness.htm
Put your confusion aside and make a punch list of the swap and how you're doing each phase. Itll take alot of guesswork out so you can focus on the important aspects and not forget anything
#177
#178
ok, im hoping somebody here can help me, i just finished doing an lt-1 swap on my 85 camaro. its finished and running. the motor and wire harness is from a 1994 impala ss, i used the original impala wire harness. the problem i am having is that i cannot get my oil press. gauge or tach to work. i want to use the original instrument cluster! everyhing else works, water temp, speed, volts, fuel, but no tach or oil press. rite now im using the signal wires from the impala harness and ran them directly to the cluster, according to all the diagrams i have seen all my wires are in the proper locations. any ideas of why they dont work?
#179
i have the motor out and i am at wiring before i put the motor back in i need to know what wires to cut and splice into the iroc wires not sure where to start
#180
sorry I cant help but Pocket built mine on my 86 using the lt1 harness and the 86 camaro the man is good with the wiring harness
#181
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I had Pocket do my swap harness. I don't understand what "red 5" means and what "p102" means.
Give me instructions that say "connect this purple wire to this green wire," and I'm good he he he. That's as far as my electrical wiring ability goes.
It's hard for me to study up on this stuff when I work 70 hours a week and go to school full time.
I'm glad guys like Pocket know what's up because it helps those of us who don't know.
I admire all the guys on here who did the wiring for their swaps themselves.
#182
i just read that red 5 is injector 6 im not sure as to where I should splice the 10 pin wires to and where the 6 red wires go and also where the 32 pin wires go
#183
Car: 92 Firebird
To answer your question though, you cut those connectors off and splice them to various parts of the 3rd gen harness. Finding the pinout will tell you what each wire does so you dont have to trace them individually with a meter
#184
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
#187
Car: 92 Firebird
To a message a user, click their name on the left and a drop down menu will appear. Select send private message to xyz
Please refrain from asking technical questions via PM. This is a public forum and many people often have the same question, so posting it out somewhere like here (if its LT1 harness related) will garner the best benefit and draw from the pool of other members as well
#188
Ok people, I went to a dealer and scanned some stuff from the service manual. I missed one connector because I remembered it's number of pins wrong, but I did get the wiring diagram/schematic of where its wires go. If someone has access to the servie manual, you should be able to see the page numbers of where the c100, c220, and c230 connectors are, and therefore it should be a cinch to scan the last connector and post it.
I will not be able to host these for long so grab them now and hang onto them for people with future problems!!!!
#189
hey all I'm thinking about doing the lt1 swap out of a 95 caprice... everything else I can deal with except the wiring... re-pinning and whatnot I can do that and have done it before so no issues there either.... is that symatic that was provided at first for the 4th gen f-body harness is it the same as the caprices??? if not could I buy a f-body harness and use that??? instead of the d-body harness??? I work at a auto salvage so used parts would be easier for me to locate.... anyone be willing to let me add them to facebook that has done the swap before incase I have any questions come time of the swap??? thanks again
#190
Car: 1992 camaro
Axle/Gears: 3:73
You can use the f-body harness it will do the same thing. Look thru the stickies Pocket has several diagrams that are better than this. The wiring is not that hard to do just read over the stickies you'll get it.
#191
Tought about my old camaro today and came to the forum to see how that thread grew over the years. glad a few of you found useful info even if my english wasn`t the best!.
I hope you all I had fun doing it, for my part I did but moved to other projects.,,
All in all it was more of a learning process in mecanics and electrical. My camaro did 13.6 at the time which was for me quite fast. I had fun.
Now a teacher in machining and electro mecanics. still talking about all this with my students.
take care all !
PS, did I see 258000 views... wooowzer!!!
take care all !
86-Transam (01-16-2022)
#192
Can a moderator please put a STICKY on this and lock it, people are sending me a ton of emails on this and I don't have time to reply to all so I figured this will be a greater help to people:
This will work for the 92-95 LT1s
If you wire the following correctly your car will start on the first attempt.
F-BODY LT1 ENGINE WIRING HARNESS.
VATS 16 pin PASSKEY II
A8| | A1
B8| | B1
Slot Wire Color Description
A1 Orn Power feed from ECM BAT fuse #4
A2 Pnk Power feed from ECM IGN fuse #5
A3 DK BLU Fuel enable signal
A4 YEL/BLK Starter enable relay control
A5 GRY "Security" indicator lamp control
B5 BLK/WHT Ground
B7 PPL/WHT Ignition key resistor return
B8 WHT/BLK Ignition key resistor feed
| | Top White 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is DK GRN and is the coolant temperature feed to instrument cluster.
J is DK GRN/WHT and is fuel pump replay control
H is empty.
G is DK GRN/WHT and is vehicle speed signal.
F is GRY and is fuel pump motor feed.
A is RED and is Alternator feed to instrument cluster.
B is TAN and is oil pressure feed to instrument cluster.
C is BRN and is oil level feed to instrument cluster.
D is empty.
E is empty or if you have a manuel tranny it is the clutch anticipate signal and is GRY.
| | Top Blue 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is TAN/BLK and is (Automatic) torque converter clutch control.
J is ORN/BLK and is (Automatic) park/neutral feed from transmission position switch.
NOTE: If this vehicle is manuel the wire would be LT GRN and would be (manuel) backup lamp feed.
H is LT BLU/BLK and is (Automatic) TCC switched power feed.
NOTE: If this vehicle is manuel the would be be BRN and be (manuel) power from turn B/U fuse # 2 to backup switch and would be brown.
G is PNK and power feed from ECM IGN fuse # 5
F is DK GRN/WHT and is A/C request signal
E is DK BLU and is theft deterrent - fuel enable feed.
D is WHT and is techometer signal to instrument cluster.
C is WHT/BLK and is diagnostic request signal.
B is service engine soon indicator feed.
A is empty.
Black Connector 4 pin
|A|B|C|D|
A is PPL and is ignition (crank starter) (connected to starter relay)
B is BLK/WHT Ground
C is ORN Power feed from ECM BAT fuse #4
D is Empty
C100. It's connected to the underhood fuse block.
|A|B|C|D|E|
|K|J|H|G|F|
A is PNK and is power feed from injector fuse 9
B is DK GRN/WHT and is A/C compressor relay control
C is DK GRN and is A/C compressor clutch solenoid feed
D is TAN and is serial data signal.
E is BRN and is Air Pump Replay Control.(connected to AIR-PUMP solenoid relay)-->(RELAY CONNECTED TO BATTERY)
F is BRN and is power feed from FANS/SOLs Fuse 6
G is PNK and is power feed from ignition fuse 11
H is DK BLU and is secondary coolant fan relay control
J is DK and is primary fan replay control.
K is PNK and is power feed from injector fuse 10.
thx for you emails I'm happy that people are refered to me for answer, I just don't have enough time on my hands.
A8| | A1
B8| | B1
B5 BLK/WHT Ground
| | Top White 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
H is empty.
D is empty.
| | Top Blue 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
A is empty.
|A|B|C|D|
B is BLK/WHT Ground
D is Empty
|A|B|C|D|E|
|K|J|H|G|F|
1995 firebird vin k L36 pcm pinout does not fall in to any of those
