LS1 swap for my '89 GTA
Old 09-16-2011, 07:47 PM
  #201
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: LS1 swap for my '89 GTA
Just a small update...
I bought new truck plug wires to match my other wires. I bought 36# injectors off e-bay & I bought new Corvette coil covers. Only problem with the coil covers is that I bought them to go with my two outlet fuel rail (built-in regulator), but they appear to be made for perimeter bolt valve covers. So the mounting points don't quite line up, but they are close. I'm going to have to work with it to see if I can make it work. They also aren't made for the accelerator cable bracket. So I will have to mod-it for that too. Are we having fun yet?
I also took my fuel rail down to get sand blasted & powder coated gloss black. It had rust on it in some tough spots to get to, so I figured that was my best bet.
Hopefully next week I can get a hold of Monster & get my new trany ordered
I want to get my harness sent off to Pocket as well, but I have a few questions for him before I can. I'll PM you Pocket.
That's all for now.
Old 10-08-2011, 05:44 PM
  #202
dprest68's Avatar
Engine: cammed LS1
I got my powdercoated fuel rail back and installed today with the 36# injectors. It looks much better
Not sure why the picture looks so weird. It must be all of the shiney stuff!
I was playing around with the coil cover and the fuel rail lines.
obviously that's not going to work!
It occured to me that the hard line was bent like that for a reason so I decided to try a few different things to see if I could figure out why. It also has a clamp on it, so I wanted to figure out where that went too. So I turned the line down a bit and it appears to be that way to fit under the coil cover and the clamp appears to go on the air flange on the exhaust manifold.
I know some of you guys don't like the coil covers, but I'm going for a cleaner look. Just my preference
Old 10-08-2011, 05:53 PM
  #203
dprest68's Avatar
Engine: cammed LS1
Question for JaysZ28, since I bought the fuel rail from him...
Do you think this is what was intended from this set-up the way I currently have it installed? Do you know if it was from a Corvette?
See where I attached the clamp... what do you think? Seems pretty rigid and fits under the coil cover just fine like this. Of course I have the wrong coil covers, but I can fix that.
Old 10-08-2011, 06:06 PM
  #204
dprest68's Avatar
Engine: cammed LS1
Just thought I'd add a little more information about the coils & coil covers. Obviously I didn't do enough research. I bought the truck coils & bracket for the passenger side to avoid the conflict with the A/C box on the firewall & the plug wires to go along with them, but the truck coils appear to be too tall to fit under the coil covers properly. The LS1 coils don't appear to fit on the truck coil bracket and the harness doesn't work either. Hopefully this will save someone else the headaches that I am experiencing. If I didn't want the coil covers I wouldn't even worry about it. I like learning the hard way... NOT! I guess I'll just have to trim my A/C box.
Oh yeah, make sure you get the correct coil covers too. Nook & Trany sells some on e-bay that are already trimmed for the accelerator bracket & stuff. Hopefully they'll let me swap out the ones I bought for those.
Old 10-08-2011, 10:01 PM
  #205
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Thats the 97-98 C5 fuel rail. Its a hard find because its the ONLY LS1 rail thats return style so you dont have to modify the fuel lines extensively. Just extend the two from the framerail. Do NOT mount the return line tab to the exhaust block off plate permanently
Also, if you ditch the hardline return for a braided line like on the other side, that cover should fit
For the pass coil cover, why not just move/tilt the #8 coil enough to clear then the cover will still fit
Old 10-09-2011, 08:09 AM
  #206
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Yep, It was from a corvette, which is why I bought it initially. It made the plumbing easy.
I would not run the return line like that. The lines ran around the master cylinder when i did it.... I even found a pic!
http://i292.photobucket.com/albums/m...t/P1000435.jpg
and FWIW, My ls1 coils cleared my ac box just fine.......
Old 10-09-2011, 10:36 PM
  #207
dprest68's Avatar
Engine: cammed LS1
Thanks for the input guys!
Old 11-04-2011, 02:06 PM
  #208
dprest68's Avatar
Engine: cammed LS1
Yay! I just ordered my trany from Monster. I ordered the Super Sport 4L65E with the level 2 shift package so that it won't break my neck shifting gears when cruising. I got the Synthetic fluid to go with it. Man, I can't wait to get the engine & trans back in the car! It could happen as early as next weekend!
Next step is to get my harness over to Pocket. I am going to order a Denny's driveshaft for it too. Finally some progress!
Old 11-04-2011, 02:33 PM
  #209
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
What kind of torque converter?
Old 11-04-2011, 03:08 PM
  #210
dprest68's Avatar
Engine: cammed LS1
I bought a TCI Breakaway Converter at Summit this past summer for $100 on sale! It was a Demo. 2400 to 2600 stall. I also bought the ARP bolts for it and the flywheel. I think I hit the jackpot since that converter lists for close to $400! I usually don't find anything at those Summit sales that I can use OR, I don't have the money when I do find something!
Old 11-05-2011, 10:39 PM
  #211
dprest68's Avatar
Engine: cammed LS1
Okay, I was doing some research tonight about the transmission lines & switching over to the braided lines like some of you have done. I found a diagram of it with the part numbers and quantities, which is cool. Thanks to whomever made that! I already have a B&M SuperCooler for my new trany, but it has hose ends already built in. Having never worked with braided hose before... is there a way to connect the braided hose to my SuperCooler? Can you just slide the braided hose over the hose end on the cooler and clamp it down? Doesn't seem like it would be that easy! Man, I hate being such a noob at some of this stuff!
Old 11-05-2011, 10:48 PM
  #212
dprest68's Avatar
Engine: cammed LS1
Also, how much hose do you guys recommend I buy. And do I need to buy the AN Hose Cutters or can I just use bolt cutters or something?
Old 11-06-2011, 06:12 AM
  #213
Pocket's Avatar
Car: 92 Firebird
Id get 20' if doing the trans lines too
See if your trans cooler fittings are removable. If so, use a common hose end and an adapter. If not, try a compression fitting
I cut the line by wrapping the end with masking tape and cutting with a cutoff wheel. Ive seen lots of methods used from the expensive shears, to even a chisel
Old 11-06-2011, 07:50 AM
  #214
dprest68's Avatar
Engine: cammed LS1
Good deal. Sounds easy enough. I guess I'll have to go buy two compression fittings for the cooler. Thanks for the info Pocket!
Old 11-07-2011, 10:30 AM
  #215
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Originally Posted by Pocket
to even a chisel
The chisel method works well, even with the stainless braid. You take a wide cold chisel and put a block of wood under the hose and use a minimum 4lb hammer. If you hit it square and hard enough the first time it cuts very clean without flaring out the braid strands.
Old 11-07-2011, 08:44 PM
  #216
Pocket's Avatar
Car: 92 Firebird
Not to scare you but braided lines are anything but easy. You will have frays, you will ***** your fingers, you will say bad things about them
I imagine the chisel method would require almost a perfect edge to cut clean. None of my chisels are like that, even the new ones
Old 11-08-2011, 06:58 AM
  #217
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i grabbed an 8" cut off wheel and used it on my chop saw to cut my braided lines (along with cutting my aluminum CAI pipes and exhaust pieces). wrapped the ends a few times with electrical tape to reduce fraying and everything came out pretty clean.
Old 11-08-2011, 10:33 AM
  #218
Rpk250's Avatar
Car: 91 Camaro RS - 87 Buick GN
Engine: LS6 - Turbo Buick
Transmission: 4l60E - 200R4
Wrapped in electric tape and a new, fine tooth hack saw, works for me.
Old 11-08-2011, 10:32 PM
  #219
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I like the cut off wheel method as well. Wrapped with electrical tape before cutting and after the cut I start the hose in the fitting just enough to flare the hose frays inward. Then remove the electrical tape before final install.
Old 11-12-2011, 08:43 AM
  #220
dprest68's Avatar
Engine: cammed LS1
I have a chop saw, so I'll look at getting an 8" cut-off wheel for it. Sounds like a pretty easy way to do it. So you guys wouldn't recommend bolt cutters then? I don't see how they would be much different from the chisel method.
I'm too lazy to use the hacksaw method!
Old 11-12-2011, 08:59 AM
  #221
Pocket's Avatar
Car: 92 Firebird
Bolt cutters? No
I do recommend having a very sharp set of wire cutters handy to trim back individual frays
Old 11-12-2011, 09:09 AM
  #222
dprest68's Avatar
Engine: cammed LS1
Bolt cutters? No
Okay, no problem. BTW, UPS said you should receive my harness on Tuesday, just FYI.
Old 11-15-2011, 02:21 PM
  #223
dprest68's Avatar
Engine: cammed LS1
Yay! Big truck delivered a monster to my house today
I can't wait to get this thing on my engine this weekend. I'm a little concerned about the length of the shaft coming out the side though. It's about an inch or so longer than the one on my other trany. I guess I'll have to put the brackets on there and see how it looks. Maybe even call Monster about it.
Monster seems to do a quality build. Now I just have to swap out my deep cast aluminum pan for the stamped chrome one that came on this thing. I still need to order my braided hose & fittings as well. I figure it will be much easier to install the braided hose on the trany while it's out of the car.
Old 11-15-2011, 07:22 PM
  #224
Pocket's Avatar
Car: 92 Firebird
Pretty
Thats a truck trans so you'll either need an aftermarket crossmember mounted TA or swap the tail housing with one from a Fbody
Yes, the trans fittings are worlds easier to install out of the car
Old 11-15-2011, 08:17 PM
  #225
dprest68's Avatar
Engine: cammed LS1
that's what I suspected. I have a Spohn crossmember & TA set-up already. So no problem there. Will I need the shifter linkage brackets from a truck to make this work?
Did you get my harness today Pocket?
Old 11-18-2011, 06:11 PM
  #226
dprest68's Avatar
Engine: cammed LS1
I installed my shifter linkage brackets on "the monster" this afternoon. I wanted to get your opinions on it since I really don't want to send this thing back to Monster.
I installed the shaft bracket like normal, but I flipped the pivot ball around. There is a bit of an angle to it. What do you guys think? I will try flipping the shaft bracket around along with the pivot ball tomorrow. It looked like it may hit the pan when I tried it earlier though.
The trany came with a nice chrome pan too
Here is the length of the shaft on my other trany.
I am going to get up under my other T/A tomorrow to see if that longer shaft will hit anything
Old 11-20-2011, 08:35 AM
  #227
dprest68's Avatar
Engine: cammed LS1
I worked on getting the new trany ready to go by swapping over all of the parts needed from the old trany yesterday. Luckily I inspected everything first. I am surprised at Monster.
See anything wrong with the first pic? It looks like something a Mud Dauber would make. I'm glad I didn't install it that way. Either the flow path would have been blocked or that junk would have broken up and went into my trany! Either option is not good. I got it all straightened out though.
Old 11-20-2011, 08:49 AM
  #228
dprest68's Avatar
Engine: cammed LS1
I tried flipping over the shaft bracket, but it didn't work as you can see in the pic below. So I put it back to the way I had it. I checked under my other Trans Am and there shouldn't be any problem with the longer shaft.
I removed the chrome pan and replaced it with my deep cast aluminum pan. What you see where the harness connects is just a home made plug to keep the debris out
I revised my dipstick connection point a little. I just replaced the nut with a nice spacer. It just looks a little better & was slightly easier to work with.
Old 11-20-2011, 08:57 AM
  #229
dprest68's Avatar
Engine: cammed LS1
When I cut the 2" hole in the firewall for the harness will I need to cut this bolt out?
zoomed out view
I'm assuming that's where the hole goes since it's the only flat spot around that vicinity.
Old 11-20-2011, 09:22 AM
  #230
dprest68's Avatar
Engine: cammed LS1
It took me forever to get the trany on the engine.
I installed the converter properly, so I knew it wasn't that. So I was thinking that the converter wasn't seating into the flywheel properly. But I was only having a problem on the right side. Turns out it was the coating that Monster puts on the trany. It was extra thick in the dow pin hole on the right side. Once I cleaned it out and sanded the dow pins it went right on perfectly.
Monster claims to install their transmissions in a car to test them before they send them to you. Seems hard to believe with the problems I have been having with it. I'm sure they did though since my trany still had a little fluid in it when I removed the pan. I sure hope this is the most awesome trany ever to make up for all of the up front troubles I have been having.
Now I just need to get the trany lines installed along with my harness and then I can put it in the car. (I'm not trying to pressure you Pocket) I still have quite a bit to do to get the engine bay ready before that can happen anyways. So hopefully by Christmas I can have this thing back in the car.
Old 11-20-2011, 09:41 AM
  #231
Pocket's Avatar
Car: 92 Firebird
Attachment 229595
zoomed out view
Attachment 229596
Up to you, but Id move it more towards the framerail
Heres where I cut mine. Headers dont get close to it either. No bolt holes were harmed. It did trim a bit of the edge of the HVAC box inside the car, but it was purely cosmetic
Old 11-20-2011, 09:56 AM
  #232
dprest68's Avatar
Engine: cammed LS1
Oh, okay. I'll look at it today. Thanks.
Old 11-23-2011, 12:04 AM
  #233
dprest68's Avatar
Engine: cammed LS1
Not a major update. I just got my correct coil covers in today and got them installed.
Much better!
I also stopped by and talked with my dyno-tune guy today and got a price on that. I still have so many things to buy to finish the swap! Seems like there is always something else to buy
Old 11-30-2011, 03:40 PM
  #234
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
yeah, I know how that goes
and I've already had a running swap once.... its fixing all the stuff I missed the first time thats killing me!
Old 11-30-2011, 10:19 PM
  #235
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
It is a sad day when you think you have everything you need for the swap, so enjoy buying new parts while you can. LOL
Engine and tranny comb are looking great. Nice combo.
Old 12-29-2011, 08:32 AM
  #236
dprest68's Avatar
Engine: cammed LS1
Thanks HP! Speaking of buying new parts... I took advantage of Hawk's sale yesterday. Here is what I bought:
BMR 3 point STB
UMI tubular A-arms
UMI tie rod adjusting sleeves
UMI subframe connectors
UMI tubular adjustable panhard bar
& some synthetic grease
It's like having a second Christmas! That takes care of most of my suspension. All I have left to buy to complete my suspension are upper strut mounts, adjustable tubular LCA's & a better set of front brakes. Possibly a set of Corvette wheels too depending on which brake kit I decide to go with.
As far as my swap goes, I haven't had time to make any progress on it. After reading through WhitedevilTA's thread though, it has inspired me to paint my engine bay the same color as my car. So that will probably push things back a few months. Oh well. I've been taking my time, so what's a few more months, right?
Old 12-29-2011, 08:49 AM
  #237
dprest68's Avatar
Engine: cammed LS1
I have a question about the upper strut mounts. I'm looking at two different styles of them on Hawk's site. there are the caster/camber plates... http://www.hawksthirdgenparts.com/82...berplates.aspx and the fabricated spherical upper strut mounts... http://www.hawksthirdgenparts.com/ca...ountspair.aspx. Which of these two would be the better option? I already bought Eibach Sportline springs.
Also, is there a need for dropped spindles for my set-up or are the stockers fine? Sorry, I'm a noob when it comes to suspension set-up. I just want to make sure I get it correct the first time.
Old 12-29-2011, 10:20 AM
  #238
dprest68's Avatar
Engine: cammed LS1
I figured I better do some research on this suspension stuff so that I don't have to get my wrist slapped. Looks like the dropped spindles are used in lieu of lowering springs to help keep the suspension geometry close to stock. Correct? I haven't been able to find a comparison thread on the upper strut mounts. Do the fabricated upper strut mounts just give the struts more travel?
Old 12-30-2011, 02:16 PM
  #239
dprest68's Avatar
Engine: cammed LS1
Since no one commented about the upper strut mounts I'll try posting it in the suspension section.
I went to the paint supply store today. I think I should have everything I need now to get the engine bay painted. Hopefully I can find some time this weekend to get started on it. You guys that have just got your cars back on the road have got me all anxious to get that engine in there now!
Old 01-02-2012, 12:34 AM
  #240
dprest68's Avatar
Engine: cammed LS1
Ah crap! I found quite a bit of rust in my cowl! I found it when I was taking the windshield wiper motor off yesterday. It's the first semi-major rust spot I have found on my car! It was hiding under the paint that was in there.
Here is the firewall side
I guess I'll have to break out the Ospho. Now I'm glad I decided to paint my engine bay. Otherwise I probably wouldn't have found this. Might be a good place to apply some of that bed liner stuff after I get it fixed.
I spent quite a bit of time this weekend taking everything out of my engine bay so that I can prep it for paint. What a PITA! Pretty much all I have left to remove is the brake booster and the bottom half of the A/C box.
I also found quite a bit of sludge in my master cylinder
Nasty stuff. I can't believe I am just now finding this! I'm going to switch over to the LS1 MC anyway. So no big deal.
Old 01-02-2012, 09:22 AM
  #241
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
progress is progress man.... keep it up!
btw, my car had rust in the same spot... it sucks
however, I got mine running two weeks ago!
Old 01-02-2012, 10:02 AM
  #242
dprest68's Avatar
Engine: cammed LS1
You bet. Congrats. Did you get everything fixed the way you wanted it this time?
Oh, I forgot to mention that I ended up buying the J&M CC plates. Colorado Speed had them on sale with free shipping. It was too good of a deal to pass up on. So, now that all of these sales are over with, hopefully I can start focusing on stuff I need to buy to finish my swap!
Old 01-02-2012, 05:27 PM
  #243
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
damn, I was just looking at those strut mounts too.... might snag them if they are still on sale
plus, I ended up having to use that SLP maf...... my maf went bad! LOL
go figure!
Old 01-02-2012, 07:05 PM
  #244
dprest68's Avatar
Engine: cammed LS1
Yeah, I think the sale ends today. Better hurry.
Old 01-03-2012, 09:22 AM
  #245
dprest68's Avatar
Engine: cammed LS1
I got quite a bit done yesterday in the engine bay. The only two things I couldn't figure out how to get off was the hood latch cable and the A/C harness.
It looks like the cable need to be pulled back into the interior of the car, but the grommit on the firewall didn't seem to want to cooperate. It's in the upper right corner of the above picture. It is disconnected from the latch by the way.
I tried pulling the A/C harness back in to the car, but that didn't work and I couldn't find the other end to unplug it. I was trying to avoid ripping my whole entire dash out! That stupid A/C box behind the dash takes up way too much space! Maybe you guys can give me some pointers here.
Once I get those two items removed then I can start getting it all sanded down. I'm not going to get crazy filling everything and making everything smooth. I just want it to look decent and get all of the rust taken care of.
BTW, those two nuts on the brake booster beside the steering column were a nightmare. Especially the top one. I was not in a good mood by the time I got them removed! Also, I am just taping up the steering column shaft. I am not removing it.
Old 01-03-2012, 09:36 AM
  #246
dprest68's Avatar
Engine: cammed LS1
It amazes me how leaves can find their way into a supposedly sealed system.
I guess it would have helped if it would have actually been sealed-up.
Makes me wonder if it came from the factory like that. I was thinking about putting it back together with a nice bead of silicone instead of the gasket. What do you guys think? I can only assume that the A/C system would be more efficient with a sealed system.
Old 01-03-2012, 09:41 AM
  #247
dprest68's Avatar
Engine: cammed LS1
It's supposed to be in the mid 70's here again this coming weekend. So hopefully I can have it all sanded so that I can get the paint on there by then. We'll see.
Old 01-05-2012, 09:11 AM
  #248
dprest68's Avatar
Engine: cammed LS1
My first item arrived yesterday of the Christmas gifts I bought for myself! It's the BMR STB. It's a top quality item. I took some pictures for those of you that don't have one yet. (better pics than what I saw on BMR's website)
I think it would have been better if they would have rotated the hole out from under the bar (bottom pic) or made the attaching plate (to the strut tower) with three holes instead of two, but oh well. It's still a nice heavy duty piece that will connect the front end together real nicely. I give it 4.5 stars out of 5. I would have given it 5 if they would have had it install on the upper strut mount points like the UMI STB does. I think this piece is probably a little bit more solid than the UMI piece though. At least it should be with the triangulation to the firewall.
Old 01-05-2012, 09:17 AM
  #249
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Attachment 231849
Attachment 231850
I wouldn't silicone that in place, you may never get it off again in one piece. Pickup some weatherstrip adhesive and reglue the gasket to the housing.
Old 01-05-2012, 09:23 AM
  #250
dprest68's Avatar
Engine: cammed LS1
I wouldn't want that to happen. Good point. I'll do that. Thanks
Quick Reply: LS1 swap for my '89 GTA
