BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
Old 04-28-2016, 08:12 AM
  #201
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
That's a big plate man! Lookin good. Did you grind the nubs down by the steering shaft? I wasn't sure what they were?
Old 04-29-2016, 09:26 AM
  #202
COTM Editor
BADNBLK's Avatar
No I left there there too, as I kinda felt the same way... they were put there for some reason lol.
Old 04-29-2016, 10:46 AM
  #203
COTM Editor
BADNBLK's Avatar
I got that big ol plate welded in and the rest of the filler panels welded in yesterday. Wasn't really taking much for pictures, but I snapped a couple after starting to grind down the welds (obviously not finished). I can start to see where this will be taking shape and I'm happy
Pre weld
Drivers plate
Old 04-29-2016, 10:54 AM
  #204
J. Chris Davis's Avatar
Getting there! Come do mine next.
Old 04-29-2016, 06:07 PM
  #205
COTM Editor
BADNBLK's Avatar
Hopefully will start looking like something after this weekend! I'll be over to do yours Tuesday night lol... Yeah right! I still question wether this was smart or not lol
Old 04-29-2016, 07:13 PM
  #206
Haha, sounds good. Keep up the good work. I think it's going to turn out pretty cool.
Old 05-02-2016, 12:17 PM
  #207
Car: 92 Z28
Damn, that is going to look slick. So basically just Booster, Wiper, Steering, and clutch coming through the wall? Are you routing all the wiring in the fender wells?
Old 05-02-2016, 05:05 PM
  #208
COTM Editor
BADNBLK's Avatar
I hope so! Yeah not too much. Most of the wiring is going through the fenders, and some will come through the firewall, and still deciding on where I will need to add another firewall hole.... Figured I'll do that when I mock the engine in to make sure everything clears as its supposed too.
Old 05-03-2016, 07:52 AM
  #209
Car: 92 Z28
That's gonna be awesome. I debated on the same, but decided on some pretty loom instead. The hole right above the sub frame on the passenger side seems to be the go to, which is what I did. It is still a little noticeable there especially with all the smoothing you are doing. I wonder if you can drop the wires down from the trans hump somewhere and just run them up the engine.
Old 05-03-2016, 09:26 AM
  #210
COTM Editor
BADNBLK's Avatar
It is! I started throwing on filler and you really get to see how smooth its is gonna look, and I am getting pumped. I chose to patch up all the holes and cut new ones the size I needed and with the pass through grommets I wanted to use. Basically we changed to up to putting everything under the dash, coils included and will run everything out to the motor in the least conspicuous way I can figure... with out getting too crazy. Trans tunnel has not been ruled out at all. I need to set the motor in and see what can be seen... Using the Holley mounts changes the positioning so I can't really base my measurements off the 89 IROC turbo LS sitting next to my car haha
I ended up using a Metal reinforced filler after your post sparked my interests. Talked with my painter friend, and he swears buy it when doing custom panel work and such.
Old 05-03-2016, 11:01 AM
  #211
Car: 92 Z28
So the teal coils are going the way of the teal rocker arms huh? I thought the set up you posted looked good. No coils looks even sicker tho.
I'm interested to see where the motor ends up with those mounts. At first it sounded like it would be way forward, but now not so much. I probably would have went with those cause I really like the trans mount, but they said you need a custom drive shaft too (which now it sounds like you might not).
Better safe than sorry on the filler, not something you are going to want to re do! Which one did you use? And I hope you have a bunch of sand paper, clogs up pretty quick.
Old 05-03-2016, 12:01 PM
  #212
COTM Editor
BADNBLK's Avatar
Teal coils will be tucked away and hidden... I liked the look, but I like it without coils even more.
I'm not worried about the shaft as currently the slip yoke at my ride height is stuffed enough to tear the outer dust cover on the output seal. It could stand to come out a little. It will be interesting to see for sure though.
Yeah likes it for the cracking strength more than anything, and recommended the evercoat m2m steel, but bondo brand metal filler would work in a pinch, so for $15 I was able to skim all my seams in my panels, with a spur of the moment change in plans.
Old 05-03-2016, 01:11 PM
  #213
Car: 92 Z28
Joking about the rockers man. Gotta put at least a little teal on the engine tho right?
I didn't think about the DS being pushed up on a lowered car, makes sense. Was hoping someone would test out the trans x member with the hawks motor mounts before I was ready to put the engine in, but it doesn't seem to be happening. Would have used the motor mounts too if they worked, same design as the others tho just different placement.
Bondo brand is supposed to be decent stuff now (3M), you should be good.
As for spraying it like that from the other thread, I would think you should be fine. Fenders and hoods ect out in the open have a big surface area for trash to hit so you have to be real careful. In this case they are kinda shielding your work area from other stuff. It looks like you have a real clean shop so I wouldn't be worried.
Old 05-03-2016, 05:48 PM
  #214
COTM Editor
BADNBLK's Avatar
I painted the back side of the throttle blade teal... haha! right now not sure that there will or wont be any teal worked in under there. Not much if there is?
Old 05-04-2016, 06:40 AM
  #215
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Not sure if you have decided on what loom to use on the exposed parts of the harness, but I switched all mine over to the nylon braided stuff. It looks sooooo much better than the corrugated tubing. I got all of mine through Summit. It's made by Ron Francis. Nice stuff! The nice thing is it's split so no need to remove connectors.
Old 05-04-2016, 08:36 AM
  #216
COTM Editor
BADNBLK's Avatar
I have been staring at a pile of the stuff for over a year now!!! I found mine through a computer wiring supply type website... My best buddy just re-did his harness and used the Ron Francis brand loom, and its exactly the same stuff. Yeah it will be used even through the non exposed areas.
Old 05-05-2016, 05:59 PM
  #217
COTM Editor
BADNBLK's Avatar
All ground down, and about to be coated with first layer of Evercoat filler...
Old 05-05-2016, 11:24 PM
  #218
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Looking really nice!
Old 05-06-2016, 07:31 AM
  #219
Car: 92 Z28
Lookin good man. What is that hole for?
Old 05-06-2016, 09:34 AM
  #220
COTM Editor
BADNBLK's Avatar
Thanks!
Plutonium filler hole for the flux capacitor I'll show it off soon enough
Old 05-06-2016, 04:31 PM
  #221
irocstar57's Avatar
Car: 92 Z28
Wow! Great stuff!
Old 05-06-2016, 05:12 PM
  #222
COTM Editor
BADNBLK's Avatar
Originally Posted by irocstar57
Wow! Great stuff!
Thank you. I feel like most of what I have been posting has been pretty boring lately lol
Old 05-06-2016, 08:43 PM
  #223
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Not boring at all. I wish I had the time and skill to take on a project like this. Lol I would just be happy with the LS swap.
Old 05-06-2016, 09:42 PM
  #224
skinny z's Avatar
Plutonium filler hole for the flux capacitor....
Old 05-08-2016, 06:06 PM
  #225
WTR388's Avatar
Car: 87 Trans Am
I saw a gorgeous LS3 swapped Chevy 2 at a show last summer (most likely the owner had the car done by someone else) and the engine bay was super clean. The wiring harness was run dead middle in the fire wall just above the trans hump, it was very tucked away and hidden, the only reason I noticed it was because I was specifically looking for how it was done.
I also ran all my extra wiring along the inner fender, which helps. I'll be re-doing my wiring to go behind the intake when I take the motor out next.
Old 05-09-2016, 09:44 AM
  #226
COTM Editor
BADNBLK's Avatar
I'm still not sure exactly where I'm gonna do it. I'm gonna set the engine in when I get the bay in primer and make sure everything is gonna line up how I have it planned and kinda move from there. I need to see the exact firewall to rear of engine plane room I have with the Holley mounts. That will determine a lot.
Headlight harness and fans will all be going through the inner fenders. I hope I have it planned and mapped out good enough to not have to re-do it later.
Old 05-09-2016, 09:55 AM
  #227
COTM Editor
BADNBLK's Avatar
From my end running a shop 5 days a week turning cars in and out quickly is the name of the game. I've busted my butt to try and keep it moving, but feels like I'm at a snails pace here, so the updates feel like on my end to be boring... Maybe cause I'm getting tired of sanding LOL!
Old 05-09-2016, 11:34 AM
  #228
COTM Editor
BADNBLK's Avatar
I stayed up real late on Friday night, and got some sanding and filling going on. Hoping to have this baby in primer by the end of the week, or at least by Monday.
I posted this on IG, but thought it was kinda cool to be able to see some of the changes. I'm sure it will be more noticeable when in one color.
Old 05-09-2016, 12:37 PM
  #229
Car: 92 Z28
Lookin good man. Will be killer when it is all painted and everything.
Old 05-09-2016, 06:13 PM
  #230
COTM Editor
BADNBLK's Avatar
Or it could be awful! I'm no painter or body man lol!
Old 05-09-2016, 07:12 PM
  #231
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Im not really a fan of the smooth firewall look, but I like the smooth inner fenders. I think it'll look good for someone who doesn't do this for a living
Old 05-09-2016, 08:01 PM
  #232
I'm no body man either, but that is looking really nice. You might have a new carrier in your future
Old 05-09-2016, 09:57 PM
  #233
COTM Editor
BADNBLK's Avatar
It's not for everyone. I'm trying
Old 05-09-2016, 09:59 PM
  #234
COTM Editor
BADNBLK's Avatar
Forget that! It's fun learning, but not quite for me to do day in day out. I'd rather pay guys to do it, and make money off that lol
Old 05-10-2016, 08:47 AM
  #235
Car: 92 Z28
Nah it'll be good, you did it right. You are primering first anyways so if you see anything you want to fix you have plenty of time to fill it in.
Old 05-10-2016, 10:39 AM
  #236
COTM Editor
BADNBLK's Avatar
Appreciate the vote of confidence! haha!
Old 05-17-2016, 01:02 PM
  #237
COTM Editor
BADNBLK's Avatar
Got side tracked with getting my wife's project done (Its really mine, but you know) in the kitchen... I did finish my heavy sanding and shaping under the hood and I'm about one step away from throwing this in primer.
Went as far as pulling off my Camaro "Condom" to wash the entire car before any taping for primer
Bad news... I found out late in the project that the cover-alls I had been wearing had a jagged edge on the lower portion of the zipper, and it cut right through the fabric of the cover-alls, and right through the protective film, and right through the paint... I have a painter friend of mine that I trust to re-paint both fenders and the nose/valance while I continue on with underhood and engine installation. Total bummer, and I'm pissed at my self for it, but honestly couldn't have been a better time to need to go in for paint.
Old 05-17-2016, 03:02 PM
  #238
Car: 92 Z28
NOOOOOO!! Damn that suck man. But like you said at least it is a good time for the car to be down, and you won't loose pace with someone else painting it.. I know I at least have to buff mine out cause I didn't wrap it up, but it's soo damn dirty I might be in the same boat here soon. I usually wear stuff without zippers when I work on it, but also got a horrific welders "tan" (burn) cause I was too lazy to go change.
Old 05-17-2016, 05:19 PM
  #239
COTM Editor
BADNBLK's Avatar
It does man, but I was bound to run into an issue. I'm looking at it like a chance to do the project with higher quality. Undercoat the inner fenders and clean up headlight wiring, and hide my new skinnyboy projector set up cleaner than the first...
We work in a shop where taking care of customers car is #1, and fender covers, no belts and such are common practice. These Cover-alls had a problem with the lower zipper causing a broken edge to tear through the fabric, I should have checked. I would chew one of my guys *** for this to a customer car... I feel like I have mentally chewed my own ***.
Old 05-17-2016, 05:21 PM
  #240
COTM Editor
BADNBLK's Avatar
Old 05-18-2016, 07:55 AM
  #241
Car: 92 Z28
Always my own worst critic too man, just gotta suck it up and move on. Having the fenders off should help routing stuff as well so the way your doing it is probably easier like this anyways. I always seem to spend twice as long doing something so I don't have to pull an extra part when it would have taken half as long to just pull it and put it back on when I'm done.
Old 05-18-2016, 08:27 AM
  #242
COTM Editor
BADNBLK's Avatar
You are so right on all comments, and I wish now I would have done this a month ago. Oh well.
Old 05-23-2016, 12:48 PM
  #243
COTM Editor
BADNBLK's Avatar
Got it all in primer late Friday night. Pretty happy as there was very few issues to find (pre-guide coat) so far. Amazing how much better it looks when its all one color haha.
Ok back to the grind.
Old 05-23-2016, 01:06 PM
  #244
Still looking good!
Old 05-23-2016, 01:38 PM
  #245
Car: 92 Z28
Lookin good dude. Just paint it and throw the motor in already!
Old 05-24-2016, 09:44 AM
  #246
COTM Editor
BADNBLK's Avatar
Still looking good!
Thanks man! Getting closer to good every day.
Thanks! I think I'm gonna toss the motor in today. I need to make sure my k-member notch is gonna clear correctly, and plan my hole/s in the firewall for wires.
Old 05-24-2016, 10:48 AM
  #247
COTM Editor
BADNBLK's Avatar
Got my core support, support mod going last night. I used a custom radiator which fits under the core support, and needed to mod the core to fit the straight up position cap. With the core cut, I couldn't stand to look at the thin un-finished sheetmetal edge. I grabbed up some 1/4" round and bent it to follow the core, and welded it in.
It's in filler now, so I'll post some better pics of that here soon enough.
Old 05-24-2016, 11:44 AM
  #248
Car: 92 Z28
All in the details man. Lookin good. Won't be able to recognize the bay by the time your done.
Old 05-25-2016, 09:16 AM
  #249
COTM Editor
BADNBLK's Avatar
After getting the core support in primer and guide coat like the rest of the bay, I worked on getting the engine set in to make sure I had no fitment issues before its all painted...
I found that the notch I had cut off a quick measurement on the pan was not wide enough. Measure once, cut twice I suppose. Really only need about 1/2" of notch to clear the f-body pan with the holley mounts. I will snap a pic with accurate measurements for anyone else benefit when I pull the motor out again.
Old 05-25-2016, 06:10 PM
  #250
toddoky's Avatar
Everything looks great, you should bring that car out to LS Fest this year.
Quick Reply: BADNBLK's 91 Z28 LS1 swap... Engine + much more :)
