Post pics of the rare colors and heritage cars!!!!
#101
Car: 1982 Z28
Transmission: 4l60
Re: Post pics of the rare colors and heritage cars!!!!
Some of those pictures were taken while I was in the process of restoring the plastic pieces so they look kind of awful, also the seats look brown and dirty in some of the pictures but I think that was just lighting.
#103
Car: 1983 Z/28, 2010 Camaro
Engine: L69
Transmission: 5 Speed
I have one,1983 Z/28 L69
#104
Car: 1992 Heritage Green with Gold
How about a 1992 Camaro Medium Polo Green II With Gold Stripes Heritage Edition. Rare?
#105
Car: 1987 Camaro T-top
Engine: current 305(LG4) awating 400ci sbc
Transmission: Current 700r4 awating T-56
Axle/Gears: stock LSD 3.23s?
[quote=green92;4575699]
quote]
I absolutly LOVE that colour, has it been repainted, it seems to look...better than some of the ones ive seen, like a slightly different green
I am thinking about getting my 92 RS painted this colour
quote]
#107
What hood is that? I am looking for a cowl hood that has that overhang and doesn't just stop, I think when it just stoops it looks kindof silly.
#108
Car: 1992 Camaro "SS Z03"
Engine: 383 Stroker
Transmission: '96 1LE T-56
Axle/Gears: Borg-Warner 9-bolt
To clear things up Heritage Car-wise: RPO code ZO3 could be ordered as white w/ red stripes, black w/ red stripes, and red w/ black stripes on RS and Z's initially. Half-way in the model year, polo green w/ gold stripes (RS only) and purple haze w/ silver could be ordered. I'd love to know the numbers breakdown of the color ordered but I believe only the total is recorded.
Here is my dads ZO3 convertible w Z blisters and my '92 Quasar Blue Metallic (also new color for '92) with silver heritage stripes.
This car I saw on ebay and I'd bet is the rarest of the rare for ZO3's: Purple Haze Z28 w/ 5.7, grey leather, CD player, 4-wheel disc..etc..
I'm not an IROC expert, but I'm willing to bet this is also a rarity, I saw if in PA, it had tan leather and 4-wheel disc.
#109
Is that last green factory? Looks way to bright to be polo...
#113
Colors were so much better in the 80s. Seems like after 91 everyone just got boring bright red, black, and white. Back during the IROC era we had the beautiful maroons and yellows and metallic blues and silvers and sunset orange metallics etc all over the place. I guess it's just a sign of the times.
My hood does that. It's a Champion Hoods and Products fiberglass hood. I think its an imitation of the Cervini hood, which is probably the best looking cowl hood you can get for these cars. It actually follows the lines of the car and whatnot. Im pretty sure that hood is a Cervinis.
#115
Engine: 383 Stroker
#116
Car: 85 Iroc
Engine: V-TEC :)
Transmission: Knuter Valved
I havent seen any 85 Silver Irocs yet. Heres mine before I went all out on it. I had replaced and repainted the front nose and grnd fx when I shot these pics. If memory serves me correctly still, I only had this for about 2 weeks up to this point. So heres one
#117
Car: '85 Z28
Engine: 383 Stroker
I love the silver IROCs, especially with red interior. This one belongs to someone on this forum but it's so slick, I had to steal the photo.
#120
Car: 92 RS Conv. Heritage
Engine: stock 305 TBI
Transmission: stock Auto
Axle/Gears: stock
The White Book says 2787 camaros produced in 1990 in number 87 medium grey. All were RS.
#122
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
can someone tell me the paint code to my car? or the color? or both? i cannot find it and have had people tell me two different codes and colors now.
#123
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
#125
Hi Jfl1960, I think it is so cool you decided to stick with the maroon color, and am glad I could help motivate you to do so Your car is coming along really nicely! My antenna was missing because I actually had that car repainted and I was still putting it back together at that point, it's got an antenna now. Also the lower red pinstripe was not stock, my dad added that to my other car way back in the day and I thought it looked nice enough to add it to this car as well. The wheels are also my original wheels from the other car in which my dad had added the red pinstripe to as well, I think the pace car wheels had the stripe. Neither of my cars came with the countour seat originally, I have a set from an later model firebird (Both contour fronts) that I was thinking of getting recovered and using for awhile but never got around to it. Lately I've been moving pieces between the cars, so the car with the Z06 wheels has all 4th gen camaro seats and the stock car got my original silver/gray interior. The car with the Z06 wheels has also been donating aftermarket suspension pieces since it is in the process of getting a LS1, C5 torque tube and transaxle assembly and tubular k member and coil overs etc.... Here are some interior shost from the car with the Z06 wheels before I moved the interior to the other car.
#126
Car: 1982 Z28
Transmission: 4l60
The dash and center console are from a 2002 Camaro. The consoles are direct bolt in for the manual transmission cars and require you to fabricate in the 4th gen shifter on the automatic consoles. They are very easy. The dash requires you to remove the stock 3rd gen side mounts for the dash (They are spot welded on and can be removed easily), and then requires some modification of the HVAC box, you also need to trim the dash pad from the 4th gen car, making a cardboard template works nicely for this. The Pillars need to be modified, many have grafted third gen ones to the fourth gen ones which works pretty well. Wiring wise I used all of the 4th gen wiring harness, since I was running an LT1 at the time this worked nicely and allowed all of the gauges to work perfectly. Do some searching around on the forums and you can find a wealth of information and pictures on the process.
#127
Car: '82 Z28
Engine: Dart 406 ci
Out of the 189,747 camaros made in 1982, only 6,788 were painted in gold metallic.
I've been searching this forum, ebay, google, and a number of other places for years, and have never seen another gold one.
#128
Got those numbers from GM and several other reliable Camaro sites and all have match so I believe the 6,788 is accurate. Gotta remember those are total of all cars manufactured 1982 and sold worldwide not just in USA. And another thing that is less than 4% of the total production run for 1982, that is a small number when you really think about it.
I personally have seen a few gold but not many.
Just do a google search for "1982 Camaro Data" and you will find this and lots more interesting info for Motor Trend magazine's Car of the Year for 1982.
#129
Yup the silver really is nice , great pic.
#130
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
My Brother had the gold matalic 82, he blew the motor. Sat in his back yard for over 15 yrs. A guy came and asked if he wanted to sell it. Sold it for $500 bucks a few months ago.
#131
Car: '82 Z28
Engine: Dart 406 ci
IM NOT SAYING THIS IS PERFECTLY ACCURATE SO DONT GET MAD AT ME
#132
Actually my car is a Canadian car too. SO if 6,788 is divided equally by 3 (sport coupe, berlinetta, and Z-28), about 2,262 Z28's worldwide were painted that color (1.2% of 189,747 total). I found a website (may or may not be a trusted source) that said about 10,000 cars were shipped to Canada. So, if 1.2% of those 10,000 cars (following the same ratio) were tossed up here to the great white north, then its possible my car is 1 of 120 canadian gold metallic cars.
No need to appologize but your thinking is right on track, don't know bout the math never checked but being in Canada yes your Gold 1982 Z28 is a low production number for 1982 and taking into consideration that a small number were delivered to Canadian dealerships that makes your very rare here for a 1982 model however I never checked the numbers for later years. My Maroon 82 Z is also a rare color for that year.
#133
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
Hey I don't know how rare my 86 Z28 is she is factory colors of dark blue sapphire metallic and silver ground effects
#134
Car: '82 Z28
Engine: Dart 406 ci
#135
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
navy blue with silver rare? I never see any, i know one other member here has one.
#136
Engine: 305 tpi
Axle/Gears: stock
#137
Engine: Cammed 6.0L LSX
heres mine dark green grey first year for that color, not alot around not sure about production numbers either though. yes oscar the heritage was a 92 option, all 92 camaros were 25th's but the heritage package was the striping option on the red black and white cars with color matched grilles. dont think think that any other colors had stripes, but could be wrong.
The heritage cars came in a few different colors:
white / red stripes
red / black stripes
black / red stripes
purple haze / silver stripes
polo green / gold stripes (RS only)
#138
1 Post
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
does this qualify for rare color
#139
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
you mean like this?
I don't think gunmetal gray is such a rare color... is it? It's not original on mine, although one of the donor cars was a factory original gunmetal gray 1983 Z28. I liked the color so I ended up painting the whole car like that.
That donor Z28 would have looked exactly like this, minus the third brake light and possibly with a different interior.
i swear i saw this car driving in the other direction past me on the interstate a week ago
#140
Heres a couple of pics of my 92 Z03 RS Heritage Edition Polo Green with Gold stripes Camaro hardtop i purchased several years ago.i plan to have it running next summer hopefully.i cleaned it up before i covered it up for the fall/winter months ahead.
#141
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
#142
Thats just fourth gen interior. Since youre new on here,look it up. Its a common Mod people do people they like the look of the 4th Generation Camaro/Firebird interiors more than Third Generation. Usually people only do the Console because the dash is difficult. But when people do decide to do it,it looks great.
#143
You couldn't pay me to do a 4th gen dash swap. I love the 3rd gen dash. It's a very unique look with a lot of character. The third gen interior was inspired by a learjet cockpit. I can understand if your 3rd gen dash and console are in bad shape and/or you have a 4th gen drivetrain. It kinda fits then, in a way. But the thirdgen interior seems to be of better quality to me and it looks a lot less like it was designed by committee.
4th gen seats are far superior, though.
It doesn't look bad and props to the guys that have done it... it definitely modernizes the car and the cupholders are nice. But convenience and modernization aren't necessarily my cup of tea in my 80s rattletrap.
#144
Transmission: 5spd
You couldn't pay me to do a 4th gen dash swap. I love the 3rd gen dash. Ts a very unique look with a lot of character. Third gen interior was inspired by a learjet cockpit.I can under stand if your 3rd gen dash and console are in bad shape and/or you have a 4th gen drivetrain. It kinda fits then. But the thirdgen interior seems to be of better quality to me and it looks a lotless like it was designed by committee.
It doesn't look bad and props to the guys that have done it... it definitely modernizes the car and the cupholders are nice. But t convenience and modernization aren't necessarily my cup of tea in m 80s rattletrap.
#145
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Heres my car its med. metalic maui blue. Dont quote me but i believe there were about 3,658 camaros this specific color code in 1991 out of 100,838 camaros built.
#146
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
here is my 87 yellow iroc i rescued from a 4/5 yr slumber it had been wrecked an set to the side by someone. the gray one is a 85 z car that was white and gold but i repainted and eventually sold.
#147
Want a title? Post!
Car: 1985 Camaro Berlinetta Sport Coupe
Engine: 2.8L V6
This would be my 1985 Sport Coupe, Angel. Complete with orange/brown striped cloth interior and burnt orange carpet/headliner/vinyl door panels. It's so ugly that it's hott
#148
1 Post
Car: 1984 Chevrolet Camaro z28
Engine: 383 sbc
Axle/Gears: Stock...this is next
Hey guys, I saw somebody post this on the first page and had no responses. My car is an 84 z28 with the light brown/gold combo. I have never seen another one in person, and they are rare even on here. How rare are these ones? Mine's in decent condition
#149
Car: 1991 Z28 Camaro Convertible
Engine: 1988 305 TPI
Hey guys give me your opinion!?
My 91' Z28 is red with silver/red rims and red interior. Would a matte black paintjob look good with a black convertible roof and the red interior and the silver/red rims? I saw a picture of a matte black 3rd gen but it didn't have a convertible roof or rims like mine and it looked surprisingly good. I was told that a matte/satin black paintjob is only 150 bucks.
This is the pic: http://sphotos.ak.fbcdn.net/hphotos-..._5347740_n.jpg
Any thoughts?
Any thoughts?
