A full list of Checks performed- 2016 Smog check/ Vehicle Inspection
Engine: 305 5.0 TBI
Transmission: 700-R4
On my 1990 RS 305
-PCV
-Cat Converter
-Egr Visual
-Fuel Cap Functional
-Fuel Cap Visual
-Spark Controls
-Fuel Evaporative Controls Functional (this is the one I failed)
-Thermostatic Air Cleaner
-Air Injection
-Vacuum Lines to Sensors/ Switches
-Ignition Timing 2 BTDC
-Wiring to Sensors
-Fillpipe Restrictor
-OBD System Checks
-Carb./Fuel Injection
-Other Emission Related Components
-Oxygen Sensor
-Liquid Fuel Leaks
I passed all except the Fuel Evaporative Controls Functional...
"Low Pressure Fuel Evap Test"
"^^^ (Most 1995 and Older as of 12-01-07)"
Its where they stick a hose up to your gas tank and test for pressure.
Apparently pressure is leaking out somewhere from my gas tank or fuel lines...
Anyone know of a test I could do to try and help find the leak??
I dont want to take it into a shop to have the chemically dyed gas test done.
-PCV
-Cat Converter
-Egr Visual
-Fuel Cap Visual
-Spark Controls
-Air Injection
-Wiring to Sensors
-OBD System Checks
-Oxygen Sensor
-Liquid Fuel Leaks
Car: Bright Blue 1989 IROC-Z Coupe
Axle/Gears: Borg Warner 2.77
Re: A full list of Checks performed- 2016 Smog check/ Vehicle Inspection
I failed the same test . . . you need to fill your gas tank before retesting in order to pass.
