Nebraska people!
#51
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
Re: Nebraska people!
Will do, I make no guarantee's that it will be on the road this summer though, but hopefully it will.
#53
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Car will be out this summer in current form plus LS1 brakes on front, stock fronts on the rear. Also picking up a '00 5.3/4L60e combo this week. After the Ford Fairmont that was on Pinks... (Youtube it) I figured, 600+ hp for under $4K. Why not?!
Now I just need to come across $3K for Turbo and upgrades.
EDIT:
Nevermind. Sold it early I guess.
EDIT:
#54
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
Painting mine next week if all goes as planned. Then I'll be cruising about.
#55
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
I am from Beatrice, and spend most of my time in the DeWitt, Plymouth area.
#56
I'm here....Black 85 Berlinetta, 305, 4 barrel, Work in progress...I'm in need of some parts. Shoot me an email and let me know what you got.
I'm in Bellevue/Offutt AFB
#57
Engine: 350ci TPI
#58
^^ I like those new blue-rubber tires you got on there! Lol just playing around, very nice job on the car though. It turned out very nice!
#59
Engine: 350ci TPI
#61
Engine: 350ci TPI
#63
Engine: 350ci TPI
#65
Engine: 350ci TPI
#68
Car: 91' Z28
Engine: 383 HSR
Axle/Gears: 4.11
Guess I've been kinda quiet on the thirdgen website for a LONG time.
North Platte Nebraska checking in. Attached picture of the car etc.
#69
Lincoln/Omaha here.....live in Lincoln, office in Omaha and travel all over NE, IA, SD, and Northern KS for work.
Just got tags (again) on the Z today so I can take her out for some shakedown runs. She's sat in various on and off camber positions in the drive and garage all spring/summer for a T5 swap, true duals, and a lot of 'little' jobs like white gauges, speedo cable, etc.
Plates have read "1986 Z28" for the last couple years- first pic is from spring when I put the engine back in after replacing the RMS, valve seals, intake gaskets, and adding a Canton oil pan. Rest are from a trip in 2007 on Route 66 from St Louis to Tulsa- wanted to make it to OK City, but my dog got hot with no a/c and 95* weather.
Drive my 'economical' truck during the week- 20mpg with 20's, crewcab, and 4x4 isn't too bad- drops to 17-18 at 85mph when I head west
#71
Engine: 350ci TPI
#72
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
With all the work that I see you got into it I think it's a fair price. I think you should add some finished pictures to the ad though so that the potential buyers can get a feel for what they are buying. You know what I'm saying?
#73
Engine: 350ci TPI
I'll get some good ones and add them, thanks. I've meaning to post it on here, there would of course be a big TGO discount haha.
#74
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I come up there periodically, I'll shout out when I do.
#75
Car: 86 Z28
Engine: 67 327cu. dart II heads
Transmission: 700R4 2200 stall
Axle/Gears: 3.73 gears
im kinda new to the site and i see there hasnt been any postings on here for awhile. kinda curious how many people from the lincoln/omaha area. im new to the area and dont know alot of people.
#76
Engine: 350ci TPI
On a side note, I am searching allll over for a 4th gen plastic tank.. would anyone know where to get one? I've been down to the boneyards a few times, but its pretty rare to see a new enough one. I thought I came across one once, but the tank was already gone.
#77
Well welcome to the middle of nowhere! I am from Omaha and while mine is all torn apart over the winter, I was driving my 3rd gen all summer long!! Owned the darn thing for two years before I got to actually drive it. And its still not very nice.
#78
Engine: 350ci TPI
I'm going to be using the stock TPI regulator, but it will be nice to have a light tank that doesn't use my trunk space, since I just have a cell now. I have -8an running the car now that will be my feed line from the pump, and then I have the stuff to hook the return line to -6 and then to the stock steel to run down the car. The fuel rail is setup for a -8an rear entry. I also found out yesterday that my lt1 injectors fit fine and I don't need to shorten the towers on the lower manifold.
#79
Most people on CL suck when it comes to email- seems texting is probably the best way......although most people that do actually answer when you call are pretty fun to BS with- my wife hates when I sell things on there and end up having a 15 minute conversation about cars with a total stranger lol.
Sounds like she's coming along nicely! Not to rub it in but I might take ours out today. Have to run into Lincoln for some more paint for my daughters room, and it will get the car out of the garage so I can make more progress organizing it- we just moved to Waverly the day after Christmas.
#80
#81
Car: 86 Z28
i drive mine as long as the roads are good. Hawk i dont live to far from you im about 10 miles straight south of waverly
#82
I feel your pain- I had to justify keeping insurance on ours for a few years because I'd make her undriveable every fall.....only been able to drive her since about August-finally got the t5 swap and new exhaust done, but being lowered and with true duals I've torn the mufflers off 5-6 times on driveways, train tracks, even pulling into the garage at our new house. My brother in law used to do exhaust for sublime in Omaha so one of these days he's going to help me tuck it all higher and weld it all up.
Am Muscle- I agree-roads have to be dry and no snow. Do you in or around Eagle I assume? I'll have to keep an eye out for you when I cruise through there. Did you go to culvers at all last year?
#83
Car: 86 Z28
no im just south of walton. no i never went to culvers i didnt move here until november. what goes on at culvers
#85
Car: 86 Z28
sounds like fun i mite have to check that out this summer.
#88
Engine: 350ci TPI
https://www.thirdgen.org/forums/tpi/641193-my-350tpi-camaro-build.html
Here's an update on what I've been doing. I think I have a buyer lined up for when its all done and I get to drive it for a month. He wished it had an A/C though...... I told him that what the t-tops were for.
#89
Car: 86 Z28
#90
Car: Many 1975 LT, 2010 SSRS
Engine: V8
Transmission: Automatic
Axle/Gears: Stock
You should check out the 3rd Camaro Fun Days in Brookings Aug 11th we have a really good time parade, show nshine, and cruise to OakWood state park we have 40 plus cars.We are on Face book 3rd Annual Camaro Funn Days. You guys have a club down there?
#91
Engine: 350ci TPI
Anyone going to Thirdgen Fest? I was kind of thinking about either hauling mine on a trailer out there, taking the dsm, or going with someone.
#92
ADV1, what color is your thirdgen? I am in the process of fixing up mine and I really like that color.
#94
I would except I don't really have enough money for that kind of gas with the paychecks I get.
#97
Just bought an 89 irocz l98 107k pretty nice got it from lincoln for pretty cheap needs a little work but im going to do. I live on base def going to that car show!
#100
If it stops raining and I can wash it I would love to the paint is not in the best condition body is decent few dents the interior is a solid 8 there's a small hole in the drivers seat... The car is all stock just got fuel injectors for it but just moved my dad had one of these so I found a cheap one and bought my background is I've been rebuilding 3000gt vr4 since I was 18 and wanted a muscle car. Anyone live on base?
