Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Who is running quicker than 12 sec. 1/4 mile
Old 11-16-2011, 06:24 PM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
Transmission: Turbo 400
Axle/Gears: Narrowed Ford 9"
If you have a combination running quicker than 12.0 on pump gas, than layout your combination. List your E.T. and mph, and what engine, trans, and suspenion set ups do you have. Lets give fellow members the upper hand.
Old 11-16-2011, 06:59 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: Who is running quicker than 12 sec. 1/4 mile
you start
Old 11-16-2011, 07:12 PM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
in sig.. Should run much better but no real testing or tuning straight off the trailer 5-6 years ago and has pretty much sat since.
Old 11-16-2011, 07:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lets see. Back when I was running pump gas way back in 1999 and 2000....
383 stroker
010 block
Cast 350 pistons
Stock 400 rods and rod bolts
Weiand X-CELerator single plane intake manifold
BG 850 Speed Demon double pump carb
Ported double hump heads with 2.02/1.60 valves
1-5/8" full length open headers
Crane solid flat tappet cam http://www.summitracing.com/parts/CRN-114691/
TH350 with 3800 stall converter
Stock 3.27 gears in a 9 bolt with 26" tall slicks
Basic stock suspension other than aftermarket components such as torque arm, LCA and panhard.
I can't remember what my race weight was at the time but I managed a 11.847 @ 117.87 MPH at altitude. It worked out to a sea level corrected of 11.163 @ 126.1 MPH. Best 60' time was 1.662
That engine was a tired old street engine. I pushed it for 2 years and made 200 passes on it, spinning it to 7000 rpm before it finally let go.
Not everybody's combination may be right for you. I never care who I line up against. Most of the time I have no idea what kind of car I'm up against. Body style or powerplant means nothing when you're on the dragstrip. Make enough passes down the track and you'll lose the inferiority complex about losing to some other type of car. If you want to run just as fast as xxx brand car, then buy xxx brand car. If you want to run a third gen then do whatever modifications you want to go fast but don't complain if some other brand can still beat you especially if it's a newer car.
Old 11-16-2011, 07:55 PM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
I just got my car to where I could drive it still not runnig to suit me yet. I have not had it to the track yet and do not know exactly what to expect. I am not sure if it will run below a 12.0 or not it should be close. But reguardless the engine is a 355, flat top pistons with 2 valve reliefs, sportsman II heads, gasket matched and bowl blended 64cc milled .025". solid flat tappet cam comp XS282S. Victor intake, 750 Mighty Demon Carb, MSD ignition. 1 3/4" headers, 3" dual exhaust. 3000 stall converer, TH400 trans, ford 9" with 4.11 gears, 315/35/17 drag radials, complete suspension upgrade.
Old 11-16-2011, 08:03 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Sounds like an 11 seconed set up to me. The only thing you have against you is the weight of the car and what power you end up with after you put it through that T-400 and 9 inch rear.
Old 11-16-2011, 08:36 PM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
More power will come later as the money allows. On the initial build I wanted start with a solid foundation when it came to the trans, rearend, and suspension.
Old 11-16-2011, 10:44 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Sounds like a solid combination. Better have some good suspension reaction to get those low pros to stick good.
Old 11-16-2011, 11:04 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
11.89@ 111
Stock block (dished cast pistons) 400sbc (9.0 compression) with a 100shot of n2o
In my sig for the rest
my last combo was a 383sbc(11.0 compression), everything the same except
11.0 @ 124.6
Old 11-16-2011, 11:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
See signature. All motor with a full weight GTA including T-Tops including all the working smog equipment and A/C. Fixing on upping the ante with new heads and a larger TPI induction system. This was with a DA of 1811ft.
Old 11-17-2011, 08:16 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
I was just stating the obvious. It's good you started with all the good stuff but it may be the only thing in your way of a 11.99 pass.
Old 11-17-2011, 10:38 AM
mw66nova's Avatar
Engine: 7.0L
11.5:1 370ci LSx, prc stage 2.5 ls6 heads, 232/240 .595/.609 efi cam, vic jr, holley 850 ultra hp, Transmission Specialties 9" 4500 stall converter, th400. moser 9" 4.11's, 28x10.5S. 10.76 @ 126 at 3450lbs. looking forward to testing this new carb.
Old 11-17-2011, 11:30 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Stock l98 shortblock, custom hydraulic roller(236@.050 and .580" lift), Ported AFR 190 heads (10.8:1), ported RPM Air Gap, 750 Mighty Demon, 1 3/4" headers to a singel 3" exhaust. 3600 Vig, 4.10 gears and 26x10.5 QTP's. 11.89@115 with a 1.65 60'. It went 11.60@117 at a sea level track. After 100's of passes, one stock piston finally let go. New pistons and better rings for this coming year. Hoping for 11.60's in my typical 3000' DA.
Old 11-17-2011, 12:31 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
11.52x @116.4x with 1.552 60ft. 388 stroker dart 215cc heads. Vic jr. Intake proform carb 850. Solid roller. 606/.606 25x/26x on a 108lsa. Th400 4500 stall ford 9"with 4.11's. Maybe 3400lbs?
Old 11-17-2011, 01:00 PM
DIGGLER's Avatar
9.44@139
stock LT1 with a cam and ported stock heads
single plane intake, 1200 cfm throttlebody
nitrous plate
th400
3.89 gear, 9" rear
all bolt in suspension stuff
275/60 goodyear radials
~3100 lbs
Old 11-17-2011, 02:48 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Not quite there yet but not far off....
Need to get rid of bog off the line....
355 cu. in. /modded intake and runners 52 MM TB
Jones Cam 228/228/113 LSA .575-575 1.6 rockers
My shorty headers/ 3 1/2" cat back exhaust
6 SDP., 3.73 12 bolt
3500 lbs. + driver
400/430 HP & TQ
12.45/110.71
Old 11-17-2011, 07:27 PM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
So far I have seen some very impressive combinations. Good old AMERICAN ingenuity.
Old 11-17-2011, 07:33 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I still need to get to the track but mods are in sig.
Old 11-17-2011, 09:44 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I'll join. 3400 lb GTA, stock shortblock, AI 226/234 .575/.575 AFR 195 eliminators (#1040's) 9:1, miniram, longtubes with bullets. Spohn k-member/ coil over conversion/ control arms, torque arm and lca's. 700R4 w 3200 vig, 4.10's, 28/10.5s.
Would really benefit from a th350, plan on switching to e-85 and ls1 pcm
Old 11-17-2011, 10:05 PM
Car: 1989 GTA
Engine: 369 TPI
"entire Spohn calatog"
Old 11-21-2011, 05:37 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Man, I'm so close...
12.02 @ 112
'82 Berlinetta, stock 2001 LS1 shortblock with LS6 cam & intake, 28 lb injectors, ARP rod bolts, Melling oil pump, shaved 317 heads, L92 valve springs, Hawks 1-3/4" primary 2-1/2" collector LTs into 3" catback w/Magnaflow single in/out; 4L60E tranny with 3500 stall and Transgo shift kit; 3.73 gears on 28-spline Auburn posi, welded axle tubes, aluminum support cover; Hoosier 26-9.50x14 Quick Time Pro DOTs. LCARBs, BMR adjustable torque arm, boxed stock LCAs w/poly bushings. Stock tune. 3450 lbs going down the track.
Oh, did I mention I drove it to work today? And each day last week? (Not on the Hoosiers, of course - I switch from highway radials to the Hoosiers at the track.)
BTW, Victor intake and 3000 stall is a mismatch. You either need more stall, or less intake. A Performer RPM would match the stall, 4500 stall would match the intake (and you probably don't have enough cam for 4500 stall). If your intake is a Victor Jr., then 4000 stall would probably work.
Old 11-22-2011, 07:21 AM
TB2
TB2's Avatar
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Some impressive setups on here.
Does E85 count as pump gas? Anyway, new motor has gone 11.30 @122mph with a 1.582 60ft. on E85. 010 decked block with billet main caps. 13.8-1 ross pistons, Eagle rods, 350cube, lightened stock forged crank, Dart Pro1 heads, 60132 Lunati Solid roller. 578/588 278/288. Pro form 850cfm. Hooker long tubes with 3" duals. Turbo400 with a brake, 4000stall, 3.88 gear w Detroit locker. 26x10 slick.
Old Pump gas Motor went 11.86 @ 116mph. The setup was everything listed above, except that it was a completely stock early LT-1 shortblock.
I'm hoping to crack into the 10's next year with new 28 x 10.5 slicks and a new cam. I drive this car on the street all the time with E85 without a problem.
Old 11-22-2011, 07:26 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Is 12.01 close enough?
It should have some 11.9x's left in it. Details are in my sig.
Old 11-22-2011, 02:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
someday I'll run that fast
Old 11-22-2011, 02:28 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Unfair my 113 2nd gear 2k launch.. puts me in the 11's by speed..
Old 11-22-2011, 02:39 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
11.63@118 was best time
406, AFR 210 (old style), 248/248 solid roller cam, TPIS miniram, Hooker Super Comps, 7004r w/ 3800 stall vigilante converter, 4.56 gears, 28x10.5's weighed about 3600 with driver.
pulled trans in favor of TH350 with 8" converter...times soon.
Old 11-22-2011, 02:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Old 383
11 to 1 comp, 4.03x3.75 383 oem block roller motor
AFR 195 heads, 8019 springs shimmed up
Bret Bauer custom grind 230/245 .603/.613 109lsa with Comp 1.6 rockers
ported Holley stealth ram, 42lb injectors
Hooker headers 2210's longtubes
4" single exhaust
700r4 trans, 3600 stall Edge racing converter, 10 bolt wth 3.42 gears.
Most all suspension bolt ons, tokico adjustable shocks/struts, weld prostar wheels, 26x11.50 ET streets/skinnies up front
11.47 at 118.x on a 1.5x 60 foot in summer 70's deg warm air.
3450lbs raceweight. 8pt roll bar included. full interior.
HSW single nozzle nitrous kit jetting 150hp shot..... 10.63 at 127 on a 1.45 60 foot.
Old Turbo combo
401" dart block 4.125x3.75
AFR 195's, 8019 springs shimmed
Victor E EFI intake manifold, intakeelbows.com custom sheetmetal elbow, LS1 TB.
Mike Jones custom hyd roller 233/233 .564" 112lsa
Twin 60mm turbos T4 turbine side.
80lb siemens injectors, dual walbro 255 intank pumps
TH400, ~5200 stall at the time, 10 bolt 2.73 gears. Weld prostars 26x11.5 ET streets as before.
14psi, pump gas only
9.86 at 141 on a 1.5x 60 foot.
~3550-3600lbs estimated..may be heavier
New turbo combo... Same as above but with Speier v2.72 heads, ported victor E intake, twin 70mm turbos, 4000 stall converter, Bret Bauer custom grind 246/252 .640" hyd roller.... Coming soon for 2012
Old 11-22-2011, 09:04 PM
Kat
Kat's Avatar
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
355/700R4/10 bolt with 3.42's AFR195's (ported) HSR (ported) mid 240's cam on a 112 around 600 lift
Best was 11.57@117.5
Here is the other week at Cecil with me not racing the car in a year. 11.80's @115.
http://www.youtube.com/watch?v=iVonK7noS8Q
Old 11-22-2011, 09:51 PM
87_TA's Avatar
406ci, Ported AFR 195s, Vr EFI, Super Comp 1.75s, T56 6 Speed, 4.10s
Strange Adj front,rear, Jegs TQ Arm, Comp Universal Drag Bar.
10.41 @ 132 best et on motor, 9.6 on spray
Old 11-27-2011, 07:32 PM
383 rs's Avatar
My car went 11.73 at 114mph with a 1.72 60
383 ci
edlebrock old performer heads w/ roller rockers and stud girdels
comp solid flat tappet cam 540/520
victor jr
demon 750 built by rapture performance
turbo 350 with trans specialties 3700 converter
hooker super comps with 2.5" duals thru flowmasters
spohn torque arm
spohn lca
factory 7.5" with 3.42 gears
car weighs in at 2810
I have it tore down putting a 9" with 4.11 gears. I hope to get a little better 60'
Old 11-29-2011, 05:59 PM
pappystoy's Avatar
Car: 1985 camaro
Transmission: 350 turbo
Axle/Gears: 3:43
i have been drag racing for about 8 years now and won a few races here and there my best run was 11:5 after i got rid of the street radials they just would not hook up ay all
Old 12-02-2011, 01:33 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
Motor in my sig. 10.36@130 TH350 coan 8 inch converter. 9 bolt with 3.45 gears. 28 tall tire.
Old 12-03-2011, 05:29 PM
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
I run E-85 in the company truck sometimes, and it is available at several gas stations so I would consider it pump gas.
Old 12-03-2011, 07:47 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
How come you didn't get your AFR castings ported? or are the Speier heads THAT much better? I really enjoy your build threads BTW
Old 12-03-2011, 08:35 PM
SemperChevy91's Avatar
Car: '88 Firebird
Engine: 355
11.85@127
355 with eagle rotating assbly, world heads, comp cams .450 lift cam, Comp 1.6 roller rockers, Edelbrock rpm air gap intake, and a holley 750. Mickey radials on the back with 3.73 gears. Can't wait to see how the 150shot pushes her =)
Old 12-03-2011, 09:14 PM
mw66nova's Avatar
Engine: 7.0L
^^127mph with that combo? does it weigh 2200lbs?
Old 12-03-2011, 09:34 PM
DIGGLER's Avatar
what is that like 7.8's @102 in the 1/8?
Old 12-03-2011, 09:43 PM
Car: '88 Firebird
Engine: 355
I honestly don't know the weight of the car. I was pretty surprised at the speed myself. I don't have enough track time to know where everything's supposed to be at and what's normal, but I was pretty happy with those numbers as a 19 year old with his first engine build.
Old 12-03-2011, 09:45 PM
Car: '88 Firebird
Engine: 355
I haven't seen the time slip in a while but i'm pretty sure it was 8.0@101 for the 1/8.
Old 12-03-2011, 11:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I talked to Tony Mamo about it and he stated there isnt much room to port these heads out. AFR's new castings are designed to be "out of the box" heads and dont leave alot of room for port work. Since I couldnt open them up as much as I needed for the new hp goals, I looked around for new heads and found Speier's heads to be perfect for what I needed. He really does do good stuff.
Old 12-04-2011, 04:27 AM
project89's Avatar
mine isnt technically there yet well i have 2 actually
first up 89 rs
92 3.1 v6
ported stock heads and intake
custom hyd flat cam
homeade stainless turbo headers
60-1 turbo
3 inch downpipe
tci streetfighter 700r4
tci 4,500 stall
4:10 rear gears
12.4@118mph @ 9 pounds of boost
car wieghs in at 34xx pounds
soe wieght reduction and a swap to 3:42 gears and it should go 11.90's to 12.0 @ 9 psi
89 iroc
355 sbc
forged factory crank
4 bolt 0010 block
.030 over forged pistons
ported 882 heads
tpi intake
megasuirt ems
twin 57mm turbos
2 stage 100 shot of nitrous
looking for 1000 flywheel hp out of it and the car should run some very low 9's
megasquirt ems
Old 12-04-2011, 05:07 AM
  #42
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Originally Posted by SemperChevy91
11.85@127
Impossible. Are you sure you looked at the correct lane on your timeslip? Not trying to be rude man, but this combo won't run 127. Or 11.85
Old 12-04-2011, 10:25 AM
  #43
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Yea I agree that is a mild build to run in the 11's and not to mention that type of mile per hour would mean your making some serious HP. Small cam and sub par heads really shouldn't make that power at all I would be impressed if it was a solid 13 second car
Old 12-04-2011, 06:27 PM
  #44
Car: '88 Firebird
Engine: 355
I could be wrong, that was almost a year ago and it was only my second time racing it. I might've looked at the wrong lane, rookie mistake. But i know recently my brother and dad ran it a couple of months ago and ran 12.47. He didn't tell me any mile per hour or 1/8 times. What do you think a 150shot would do to that combo?
Old 12-05-2011, 07:45 PM
  #45
camaro2's Avatar
Car: 1986 Camaro
Engine: 355
12.02 @ 112
I am not going to disagree with you, but I plan on just driving it until I decide what I want to do with an engine upgrade. It has only been on the road since mid October and I would like to take it to the track next spring to get a base line.
Old 12-05-2011, 09:05 PM
  #46
Street Lethal's Avatar
I can see maybe the 11.85 with a terrific sixty foot with that setup, but then again it was only his second time racing so I doubt he was below 2.00 in the sixty. As far as the trap though, I agree, 127-mph is way too fast for what he has. Perhaps he meant 11.85 @ 117-mph, and even then I can't see that happening with an essentially green driver...
Old 12-05-2011, 10:15 PM
  #47
mw66nova's Avatar
Engine: 7.0L
that combo has 108-112mph written all over it....
Old 12-10-2011, 09:06 PM
  #48
Car: '88 Firebird
Engine: 355
So after a lot of going back and forth with my dad on what I really ran, I had my brother pull my old slips from that day out of my room and the one I was thinking I ran an 11.87 at 127 was regretfully the other lane. My time was 12.283 at 116 with a .036 reaction time, and 1.98 60' time
Old 12-11-2011, 12:46 AM
  #49
xpndbl3's Avatar
Car: 1984 Z28
I'm going to be honest and say I can't even believe it mph'd 116.
Old 12-11-2011, 11:48 AM
  #50
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
x2 but oh well
Quick Reply: Who is running quicker than 12 sec. 1/4 mile
