Official Tampa, FL Area Thread
#1951
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Re: Official Tampa, FL Area Thread
You want me to get you in contact with Will? He might have an idea on your issue.
Well, I WAS going to order tires today, but I don't actually have the money lol. I've got exhaust and a new thermostat coming tomorrow, Saturday the exhaust goes on and I'll be doing the thermostat whenever, gonna put a correct housing on while I'm at it.
#1953
Car: 1987 Trans am
Btw here's a video I made if anyone wants to pass it on or can think of anything.
#1955
not to be a comedian, but it sounds like somebody put popcorn in there. when did the noise start? have you done a plug reading or checked at night for a crossfire/arcing condition? maybe its re-igniting like a lean pop in a hot muffler? hows it smell? rich/lean? any valvetrain noise?
#1956
Car: 1987 Trans am
#1957
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
what do your plugs look like? it runs better at start up (rich mode), and then starts to lean out? could be lean popping. are your plugs white?
see if you can borrow a wideband from someone
#1958
Car: 90RS Conv.
Transmission: th400
iwas beating the car on the way home Monday night, when all of a sudden 2 back fires and no power, then nothing but smoke...
luckily.... the top radiator hose blew off and soaked my msd boxes, and the engine bay...
on the bright side... look at all the time I saved not having to flush the cooling system this winter.
#1959
Car: 1987 Trans am
Haven't really confirmed this but I'm 90% sure its my fuel pump. October 9 2013 I replaced my Airtex one with a ACDelco one because of the problems it'd give me after heating up. It was not long after that I started having the miss problem. I have a video I took October 13 2013 that shows the same exact thing. Rapid popping from the exhaust, better with EST disconnected. It's the only thing I can think of. Been over just about every sensor, new engine and intake, different computers and memcals, my fuel delivery is all new aside from the pump. I also have a off idle hesitation if I stab the throttle when warmed up. I'm getting a fuel pressure gauge but the timeline is pointing straight to the pump. I even posted here about it October 26 2013.
#1960
#1961
Car: 1987 Trans am
That's what I was looking into. The Racetronix one looks good and has a wiring upgrade option for our cars as well. Anyone run something like this?
#1962
Car: 1987 Pontiac Trans Am
Engine: 305cu. 4BBL
Transmission: 5 speed manual
#1963
Engine: 305cu. 4BBL
L98 I told you i would find it lol. Here it is from Ebay heaven clear distributor cap and rotor lol. http://www.ebay.com/itm/Chevy-GM-HEI-Clear-Distributor-Cap-Rotor-Module-Tune-Up-Kit-SBC-BBC/331016449457?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D32481%26meid%3D3e4aca08508f48e8a9e4c16b1741de3a%26pid%3D100010%26rk%3D5%26rkt%3D5%26sd%3D181870214693
#1964
Car: 1987 Trans am
When I took my plugs out to swap out my headers they were all identical. Nice tan color. I was looking into the wideband. Think I got it dialed in to a fuel pump issue though. I'll have my fuel rail mount gauge soon.
#1965
Car: 1987 Trans am
L98 I told you i would find it lol. Here it is from Ebay heaven clear distributor cap and rotor lol. Chevy GM Hei Clear Distributor Cap Rotor Module Tune Up Kit SBC BBC | eBay
#1966
Car: 90RS Conv.
Transmission: th400
i have a inline fuel pressure gauge. im not sure how high it goes tho. I know it worked on the wifeys 91 when her fuel pump took a deuce.
ill take a look
ill take a look
#1967
Car: 1987 Trans am
Been having a slow drain on my battery overnight. Been going on for awhile. Turned out to be my heated O2 sensor. That was interesting.
#1968
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
so i wanted to stop in and drop a line because ive been a stranger around here. car still isn't got the engine and tranny rebuilt, all new suspension. full mod list now
drilled slotted big break kit.
hawks ceramic brake pads.
full poly bushings, including poly trans mount,
solid motor mounts.
kyb shocks up front
belltechs in the rear
373 running gears
locked to posi all the time
edlebrock non adjustable torque arm.
lake wood steel boxed control arms for the rear.
tubed pan hard bar
sub frame connectors.
onto the tranny
rebuilt 700r4 built to stage 2
corvette servo
monster transmission shift kit
superior 4th gear servo
trans cooler
bm ratchet shiftier
aluminum drive shaft
B&M hole shot 2k stall torque converter
engine mods
tore the stock block out and replaced it with a 4 bolt main
flat top hypernetic pistons
hypernetic connecting rods
steel crank
billet aluminum pulleys
high flow oil pickup and pump
electric in line fuel pump
(tore the tune port out and went carbed)
holley 700 double pumper
eldelbrock air air gap intake
305 heads that have been ported and polished. (for now plan to move up to vortec heads)
comp cam springs
comp cam chromoly pushrods
comp cam lifters
comp thumper cam (i for get the duration) i think its 279/297 .488 lift makes power 2k-5800. was matched to the intake.
full msd ignition kit.
MSD 6al
MSD wires
MSD distributor
hooker "shorty" headers. true dual exhaust all the way back to dual 40 series flo masters.
2 core aluminum racing radiator
chrome a.c compressor
chrome power steering pump
chrome water pump
chrome harmonic balancer
metal mesh hose "dressup kit"
that is what the final build came out to im sure there is stuff i am forgetting lol, if i remember ill update. and ill post pics later tonight its been a long road now shes almost ready for interior and paint.
solid motor mounts.
kyb shocks up front
373 running gears
tubed pan hard bar
onto the tranny
corvette servo
trans cooler
bm ratchet shiftier
engine mods
steel crank
comp cam springs
comp cam lifters
MSD 6al
MSD wires
MSD distributor
chrome water pump
#1970
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
#1971
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
http://www.sumterswapmeet.com/ is where i found about 73% of my stuff for the TA in fact i will be out there next month
#1972
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
#1974
Car: 1987 Trans am
Got the adapter I needed to mount a fuel pressure gauge on my fuel rail. Gonna get a gauge tomorrow. Hopefully it'll tell me something and overall I think I'm 10psi short on fuel for my setup. Gotta look into an afpr, it's the same the mid-late 80's grand national uses.
#1975
Posting here cuz I'm in Tampa Bay and I don't want to ship...
Selling a Used...
Spohn Standard Duty Adjustable Torque Arm & Cross member with Drive shaft Loop for 700R4 and T-5 Transmission
The red torque arm, I bought really used and the black cross memeber I bought last November... It was amazing how different the car felt with this... But as you've read here and for many others, it made clunks... if you got a loud race car, may not hear it... some say get better bolts, etc...
Cross member was trimmed to fit Alston SFC's.... NAPA trans mount included (a few weeks old...)
Sells for $450+ new
$200...
1 bolt missing in pic (tq to cross member) at mechanics, will get in a couple days...
Full add & more pics in classifieds... Preference to local buyer...
https://www.thirdgen.org/forums/engi...ml#post5964582
Selling a Used...
Sells for $450+ new
$200...
#1976
Engine: 305cu. 4BBL
Hey yall. Update. Still no leakage from the bolt which Is awesome. But still got that light flicker going on and now has a decent missfire that I cant figure out. Happens on idle and slow acceleration. Plugs, wires, cap and rotor all new. Carb was pulled and cleaned with new accelerator pump. Any ideas?
#1977
#1978
Car: 90RS Conv.
Transmission: th400
anyone have a serpentine style vacuum pump/ with the hoses , kicking around that they don't want anymore?
#1979
Car: 1987 Trans am
#1980
Engine: 305cu. 4BBL
It was very faint. As of a week or so ago it got worse. Amd tonight ugh...started overheating. Hoses super hot but radiator not as much...getting frustrated
#1983
Engine: 305cu. 4BBL
It did it both ways stopped and moving it was all over the place. But 5 min drive and it was like 250 degrees. Well I deleted the heater hoses.Since I dont use it. And removed the thermostat for now when I drive later ill see if it heats up again.
#1988
Car: 1987 Trans am
New Racetronix kit installed. Absolutely no change with the miss at all. Talk about a slap in the face.
#1989
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Now I have a 9" and I'm happy, lmao
#1994
Engine: 305cu. 4BBL
Car dies today and wouldnt start had flames coming from exhaust. Towed it home and got new icm and coil since it seemed like a ignition prob. It starts only by holdung the gas pedal down but cuts off if you let it go and **** it smokes like hell....so idk. I need a reliable car now so I might have to say bye to this one. Figured ide let you guys kbow first....incase yall have any ideas...
#1995
Car: 1987 Trans am
Damn that sucks. Wouldn't even know where to start on a HEI setup as far as diagnostics goes. Maybe Joe or Dalton could chime in on that.
#1996
Engine: 305cu. 4BBL
Well got it to work. Now the carb is flooding bad. Looks like a jug of fuel was poured into it. Getting towed again. Ill take apart the carb and check to see if the floats are still good. And see if the needle and seat are working properly. Missed work 2 days cuz of this ugh what a start for a weekend.
#1997
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
#1998
Car: 90RS Conv.
Transmission: th400
I agree. Probably caused by the fine rust dust in your fuel tank.
If it does it again, whack the bowls of the carb with a screwdriver handle. Itll knock the float free.
Your gonna need to seal your tank, or get a new one.
#1999
Car: 1987 Trans am
If you plan on keeping the car there are 2 Thirdgens at upullandpay now. One is a tbi 89 Camaro.
#2000
Engine: 305cu. 4BBL
hmm...go there or order a new tank from rockauto.com for 189 shipped....decisions decisions.
