Fuel sending unit fix
Car: 1991 RS Convertable
Engine: 305 TBI
Hello fellows, when I do a hard stop the gas gauge moves down about 1/4 a tank, if my fuel level is lower than a 1/4 tank the vehicle will stall. If I have more than a 1/4 of gas on the tank the fuel gauge will still come down when I do a hard stop but the car will not shut off. Will replacing the fuel sending unit help with this issue? 1991 RS 305 TBI
anyone in the Murrieta/Menifee area that can help bring the tank down?
Re: Fuel sending unit fix
Not much you can do about the pointer moving up/down.The supply issue could be fixable, but i wouldnt know unless i dropped the tank.Maybe the fuel pick up/sock.
Some later models had baffled gas tanks to help with fuel starvation.That would be one possible solution to both issues.
Engine: 305 TBI
The original fuel tank was replaced with a Dorman fuel tank model 576-183, I have the same issue with both tanks. I did notice inside the original gas tank a broken plastic inside, not sure if that is the baffle, I did not notice any plastic inside the Dorman tank, once it comes down I will take pictures. attached are the pictures of the inside of the original tank.
1991 original gas tank
