I've moved my 4th gen wheels to my '87 IROCZ
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have seen many posts on this issue, so I wanted to share my experience on this swap. I have two cases to discuss, A) '99 Camaro SS wheels 17x9.5 with 50mm offset, and B) aftermarket 4th gen wheels 17x9.5 with 54mm offset for the front and 18x10.5 with 58mm offset for the rear.
A) The 17x9.5 wheels are my factory wheels off of my '99 Camaro SS. These wheels have 50mm offset. These wheels will fit our 3rd gen cars if you purchase the correct adapters. For 1LE brake, you should purchase 1.7" adapters for the front, and 2.0" or 1.7" for the rear,, the 1.7" are best. I have P275/40R17 on all four positions. No rubbing and the car drives fine. If you have the standard disc brake system up front, purchase 2.0" adapters for the front.
B) I purchased black center Z06 type wheels for my '99 Camaro SS. However, I wanted to see if they would fit the IROCZ also. The front wheels are 17x9.5 with 54mm offset. These wheels with P275/40R17s fit great on the front with 1.7" adapters. The rear wheels are 18x10.5 with 58mm offset. Now here was a challenge. But it turned out great. With 2.0" adapters on the rear, the P295/35R18 BFG Drag Radials fit great, having just enough clearance. These new wheels look great on my IROCZ, so good that I am going to run them on the IROCZ for a couple months. The 295s look totally awesome when viewing the car from behind, and that is what most people see of my car, the rear end as it disappears!!!!
When it comes to wheel upgrade, us 3rd gen car owners have choices, some very good ones too!
BTW: I purchased my adapters from Skulte, I highly recommend them if you need adapters.
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
Re: I've moved my 4th gen wheels to my '87 IROCZ
hey man i wanna meet up with you and see the rear combo on your car. im looking to run the same thing on the rear of mine. 295/35 sounds big. i would like to see it in person before i run out and order my c5 rims.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Good stuff man. I just got bought some 2.0" spacers for my SS 17x9.5s from a 96 SS and was hoping I'd done right. I have the 4th gen rear, so I don't need the spacers there. I plan to get a pair of 17x11s for the back at some points for 315/35-17s...long time in the future, lol
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
I thought that I would bring this back from the dead.
ecetim,,, if you send me an email, I will send you a pic.
Just brought these for my 85 IROCZ, With a 58mm offset as well. But I have a fourth gen rearend. Do you think the rear wheels are going to stick out too far? And if not pls let me know what size adapters I need
1992rs/ss
16
01-28-2016 09:58 PM
Omega
10-01-2015 02:20 PM
AkDrifted
08-17-2015 07:45 PM
