Taller Spring for rear
Old 05-05-2010, 02:41 AM
89RSCAMAROMAN's Avatar
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
I have an 89 Rs Camaro with ttops, 305, 5 speed. I am running deep dish wheels and have pretty wide tires in the back. The tires rub on wheel wells and I am wanting to put a bigger spring in back to stop this. It rides fine till i get people in the car or sharp turns or dips in the road. Was wondering if anyone knew what spring would be taller out of another car. i was thinking a caprice or something but not sure what springs i have, and what springs a caprice has. wanting a inch or 2 taller then what i have now.... any suggestions
Old 05-05-2010, 06:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Taller Spring for rear
One cheap and easy way to raise the rear is to use a fourthgen spring isolator, which will get you an inch or so, IIRC. Add Moog 5665 rear springs for more height.
JamesC
Old 05-05-2010, 09:20 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
jegs or summit has these rubber 1' spacers they sell to raise your springs....
Old 05-06-2010, 12:07 AM
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
okay i will look into both those. thanks guys.
customblackbird
08-15-2021 10:16 PM
Orr89RocZ
04-25-2016 08:28 AM
sailtexas186548
08-26-2015 03:32 PM
kevyb1973
08-24-2015 04:11 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Taller Spring for rear
