"OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
#652
Engine: 6.5 turbo diesel
Transmission: 4l80e
Axle/Gears: 3.21
Re: "OFFICIAL" Lowered 3rd Gen Picture Thread (Post Your Pics Here)
no pics as i removed the engine , but mine sat so low me and my dad had the get out while it was in gear and push/lift to get it over a wallmart speed bump , when the front tires are flat the nose touches the ground , its a trans am with the front grill things , and it looks bad *** , wish i could drive it like that , btw i have 14`s on it , for now , also theres less than 2 fingers width between the trunk floor and the ground the way it sits now
#653
1 Post
Car: 1985 Iroc Z28
Engine: 5.7L TPI
See picture/info in signature!
#658
1 Post
Car: 1985 Iroc Z28
Engine: 5.7L TPI
Thanks!
It feels maybe a little bit more stiff than stock. Barely even noticeable really, but I thought the car felt good with stock springs as well. The air dam under the car scrapes a lot now though lol.
#662
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
this is my car on eibach sportlines and 18s
Uploaded with ImageShack.com
here is my friends bird on springs with about 3 coils cut
#663
Transmission: 4l80e
Axle/Gears: 3.21
i love your friends ride height , but the rear is a bit high in comparison
#664
#665
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
1991 RS. 1.5" lowering springs 275/40/18's
#667
Car: 1982 Camaro
Engine: 2.8 V6
Hey guys,
I'm thinking of lowering my 82 and was wondering what height some of these are. Also, what size are your wheels. Not sure if I should go 18's or 20's.
Any help/pics would be great
#668
1991 RS
Lowered 1&1/2" on 18's
Powerstroke0178 (04-25-2022)
#669
Car: 1988 Pro Am I
Engine: 305 tbi crane cams compucam
Axle/Gears: 10 bolt 2.73
#670
Car: 1988 Pro Am I
#671
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
what ya'll think? imam strip and polish the wheels soon Attachment 266991 don't know how to make pic bigger... took it with my droid bionic
Before you do your wheels, go on a search and destroy for rust. Keep that nice car under you.
#672
Car: 1988 Pro Am I
tanks for the compliment.. and car is totally rust free except for spots on lower doors where ground effects used to be. we have owned this car since dec '87 bought it off the showroom.. has like 250,000 miles on the body now. I have turned every bolt on this car since warranty ran out
#674
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Car: 1989 Camaro IROCZ, 1982 Camaro Z28
Engine: 350ci
Transmission: 700r4, TH350
Axle/Gears: 2.73, 3.73
#682
Car: 82 Trans Am
Engine: 305 ci V8 4-bbl
Transmission: TH200C
Axle/Gears: 10 Bolt/3.23 posi
Ok, here's my Trans Am with Vogtland springs. Drops 1.2'' all around.
#684
Car: 82 Trans Am
Thank you! Yes the stance is way better than before. Below some pics of how the car sat on the old MOOG springs. It wasn't sitting too high either, so lowering it a bit with good springs does the job well.
#685
Car: Camaro IROC-Z 89
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
18" XXR Rims with 285 rear tires .
#686
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
#687
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
Eibach lowering springs .
#688
Just got my weight jacks installed... Still trying to get them all evened out how I like them. It's surprisingly hard to find perfectly flat ground to adjust them on.
You can see my PHBRB and LCARB and rear adjusters here... Note the Y-pipe from my long tubes. You can see the collector flanges on either side of the transmission shining in the light.
And with my autocross wheels on...
#690
Car: 1991 Z28
Axle/Gears: 3.73/Tru Trac
Eibach Sportlines with .75 coil cut in the rear and heater hose for the isolator. 18" Boze Pro Tourings.
#693
Engine: 28xxx miles
Transmission: TH700
Axle/Gears: 2.77 BW
No I didnt . I followed the concept of another member on the board , and redrilled the rims . Changed the lugpattern to Chevrolet . I also had spacers made to get the width I preffered , and equipped them with lugs aswell , so I could fill the 5 spareholes with rimnuts . These aftermarket rims got 2 different lugpattern and I didnt like the idea of empty holes :-)
#694
Car: 1991 Z28 Camaro
Engine: Forged 346
Transmission: T56 stage 2 Tick
Axle/Gears: 4th gen 10 bolt/ motive 4:10s
Not on here much but I'll share my lowered third gen. Eibach sport lines trimmed with new Monroe socks. Ls1/60e swap
#699
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
#700
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Can you provide some more info on your tire/wheel combo?
