Sub-frame removal issues
Hey everyone, got a few questions. Long story short, I'm trying to drop the motor from the bottom. I'm having trouble with my passenger side wheel, the PO stripped the lug nut VERY bad and not I cant get anything to stick on there. I'm thinking about drilling it out tomorrow. I was going to try and dremel it out, but then I'd kill the wheel. I tried to avoid the whole thing and drop the sub-frame with the wheel on still, so I attempted to remove the strut mount from the top and broke that stud, now I'm really stuck. Probably will have to drill that too (struts are shot anyway). So my 3rd solution was trying to disconnect the knuckle from the strut by the 2 bolts, but the adjustable wrench would not stay on with all the pressure I was putting on it. Gonna buy a 24mm wrench tonight.
Any suggestions?? This wheel is holding everything back so much right now.
Also is there a write-up anywhere on how to drop the motor through the bottom? I've seen pictures of people who completed the job with the engine on a dolley and car in the air with a few words to describe the process, but no detailed walk through. I found an excellent write-up on a different site, but that was for an LT1 out of a 4th gen.
Last edited by lwcunningham; 09-01-2013 at 11:28 PM. Reason: Tried adding HTML images, didn't work.
Received 1,672 Likes
Re: Sub-frame removal issues
Any suggestions??
4th gen is a TOTALLY different matter.
Fronzizzle
03-18-2019 08:29 PM
NBrehm
08-25-2015 11:49 PM
