Spindle specs
Car: 1988 trans am gta
Axle/Gears: 4.10
Spindle specs
Does anyone know how much torque goes on the 2 nuts that connect the spindle to the shock? also, how much torque is needed for the spindle nut?
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Spindle specs
Either way, (please search, my info is not good enough for something that important. You want to be sure) and you will find the torque and probably the info about cheating torque with grease.
the spindle nut does not have a torque setting. you tighten them by feel. spin the rotor and tighten the nut real snug but don't ever crank on it. when you can't turn the rotor, loosen the nut. this is to set the bearings. If they are brand new bearings, you'll want to do this several times and again in a couple hundred miles.
To finish the job, snug the nut to where the rotor turns well, doesn't have any play or wobble, but not tight enough to impair the rotors turning. If the cotter pin holes don't line up, tighten till it does. Clear as mud?
Good luck!
Car: check
Engine: check
Transmission: check
Re: Spindle specs
125 ft/lb
Followed by a 120* turn
Final torque must exceed 148 ft/lb
For the spindle/hub retaining nuts, I use a dial indicator and shoot for 0.0015 to 0.002" end play (1.5 to 2 thou). GM spec is 1 to 5 thou.
RBob.
rb85TA
26
09-14-2015 10:29 PM
