vortec engine parts
Car: SOLD!!!!!
vortec engine parts
i have searched and read about the vortec cams. 1998 is the longblock i have. block and heads are cracked due to overheat. cylinder #3. it only has 80,000 miles. the cam is there, the valvesprings and all. i have my 305 carbed right now. i am fixing to go back to tbi. 1st reason is an ls1 is in the future. i need the harness i just purchased which is not cut one iota. so .
1. i am going back tbi.
2. i know the cam will fit
3. from checking the valve springs will also work
4. also the timing set will work but i will buy new.
5. i know that i can also use the valve springs.
6. i have shortie headers and no smog along with magnaflow catback
7. how much tuning will be involved in getting it running.
1992 rs 305.
1992 rs 305.
Car: SOLD!!!!!
Re: vortec engine parts
maybe a little more specific. will it need tuning to run without turning on the ses light. i know it wont run to its potential.
Car: SOLD!!!!!
wow i thought at least one person had changed over these parts ( mine since free) and either got it running without a tune or needed one to turn the light off.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
It will probably run okay after swap since the stock vortec cam has only slightly more duration. The more duration and less LSA, the more tuning will need to be done.
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
dont waste your time, its the heads you want.
if your vortec heads were good id say go for it,but just the cam and no tune,you will make the car slower.
Car: SOLD!!!!!
ok that is what i was wondering. the heads are cracked. darnit. i was thinking the cam would help out for lift and duration. figured since it was between the lt1 and l03 it would at least help a little.
84z96L31vortec
08-20-2017 12:16 AM
Fast355
12-02-2016 06:33 PM
84z96L31vortec
08-10-2015 08:27 PM
