how do you use a craftsman advance timing light
Old 07-29-2002, 07:40 PM
jfox55's Avatar
Borrowed and advance timing light from someone. They had never used it and didn't have directions. Is the correct way to use one of these to set it at what degree you want your engine to be at, and then it should show up at 0% before tdc on your guage. ex If I want my engine to be at 35%btdc at 3500 rpms, I would set the timing light at 35% and when I take the car up to 3500 rpms it should show 0 on the scalel Does this sound right???? It is a craftsman advance timing light with the dial. Thanks
Old 07-29-2002, 07:42 PM
jamesbern's Avatar
Yes, you are correct. It works exactly like you said which is very convenient when setting total timing on a carbed engine.
Old 07-30-2002, 07:31 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
just an fyi, if you hold 'alt' while you punch in 0176 on the number pad on the right side of your keyboard, it'll make the degree symbol. you want 35°btdc, not 35%btdc.
Old 07-30-2002, 07:43 AM
ronterry's Avatar
Car: '94 Corvette
If it doesn't zero out @ 3500, then adjust the gun up or down till it shows 0 on the balancer. Read the gun, and that what you have @ 3500.
BTW: They call them a dial back timing lights, A must if your serious about the correct timing.
RonŠ
Andrew6.688
12-13-2015 10:59 AM
tnrednneck
08-13-2015 08:57 AM
Armored91Camaro
08-12-2015 09:41 AM
Omega
08-10-2015 12:46 PM
Thirim
08-09-2015 06:19 PM
Quick Reply: how do you use a craftsman advance timing light
