PCV or no to PCV, that is the question.
Old 05-23-2004, 11:11 AM
  #101
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Originally posted by OMINOUS_87
You got it, at WOT there should be no vaccum in the intake.
At WOT, intake manifold vacuum is not 0. It is low(er) than at part throttle or idle, but not 0.
(more like .5"H20 to 1" H20.) Crankcase pressure is high(er) so crankcase air still flows into the intake through the PCV while@ WOT.
Air always flows from high pressure to low pressure.
If intake manifold vacuum @ WOT was 0, no air would flow into the engine at all. The only time the intake manifold vacuum is 0 is when the motor is not running.
Old 05-23-2004, 06:49 PM
  #102
25THRSS's Avatar
yes, sometimes it does take quite a few tries to actually have your question answered, but in the end it's worth it.
Old 07-03-2014, 04:53 PM
  #103
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Re: PCV or no to PCV, that is the question.
So retarded question but can you have a double pcv setup withe the inline filter on driver side to hopefully suck out more crap...... Instead of pulling from. Just one pcve to pull from 2 from the same bank?
Old 07-03-2014, 05:14 PM
  #104
happyhapka's Avatar
Or let's blow it out of proportion.... Using the smog pump as a crankcase vacuum
Old 07-03-2014, 11:06 PM
  #105
B4Ctom1's Avatar
Car: 1992 B4C 1LE
The problem is is that none of our smog pumps have a hose hook up for the inlet side they just have vents on the outside of the smog pump. Ford guys of been doing this for years with 5.0 mustangs to improve vacuum and ring seal on the inside of the crankcase.
Old 04-21-2015, 07:48 AM
  #106
85MaroMikezz4's Avatar
Car: 85 Camaro sport coupe
Engine: Crate ZZ4 Lt4 hot cam roller rocker
Transmission: 700r4 shift kit Vette servo coold
Axle/Gears: 4th gen rear
I have a zz4 crate I dropped in this winter. I just broke 300 miles in the break in and now every time I start the car it smokes out of the breather tubes. Have a Holley 650 carb.
Issue started Friday so I installed a pcv valve on Saturday and the issue remains.
The motor sat wrapped on a garage floor for about 7 years. No smoke out the tail pipes, oil is not too full, timing appears right, compression seems to be there only issue is the smoke. Any thoughts are helpful thanks guys
Old 04-21-2015, 05:17 PM
  #107
B4Ctom1's Avatar
Car: 1992 B4C 1LE
There is a possibility that based on your driving habits that the engine's rings are not fully seated. A slimmer chance that your cylinder walls became corroded a bit. I wouldn't freak out too much yet.
Pac J
05-17-2020 10:44 AM
NZKnight
10-15-2015 02:47 PM
sleprock
09-24-2015 04:33 PM
CatmanFS
09-19-2015 09:00 AM
Ian Irvine
09-04-2015 08:08 AM
Quick Reply: PCV or no to PCV, that is the question.
