What sensor for dashboard temp gauge?
Old 06-11-2001, 11:37 PM
rondubbs's Avatar
what sensor is used to give the dashboard temp gauge its reading?
1988 GTA Trans Am 350tpi: 48k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, homemade cold air induction, flux capacitor@ 1.21jW, driver side floor mat removed
1/4 mile - 14.58
Old 06-11-2001, 11:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The one in the driver side head.
Old 06-12-2001, 12:03 AM
rondubbs's Avatar
the fan switch?
mike you got AIM up yet so i can just IM you for a quick response?
Old 06-12-2001, 12:12 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll turn it on right now, keep forgetting...
Old 06-12-2001, 12:13 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You're not there. Oh well ...the fanswitch is in the pass. side head, back between #6 and #8, the ECM CTS is upfront in the intake, and the temp sending unit is in the driver side head.
[This message has been edited by 8Mike9 (edited June 11, 2001).]
TrevinE
09-14-2015 03:20 PM
86IROC112
09-11-2015 04:04 PM
FormulasOnly
09-10-2015 09:07 PM
85Special
09-03-2015 04:21 PM
Quick Reply: What sensor for dashboard temp gauge?
