fuel pump swap
Old 05-14-2005, 09:33 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
fuel pump swap
got a new fuel ump for my engine swap 255lph from thunder racing.
any tips or tricks i should know?
also someone told me that i might be able to get at it from the cargo area???? idk, i doubt it.
Old 05-14-2005, 09:42 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Some guys like to cut a hole in the cargo area and make a door to be able to replace without droping the gas tank. But if not done right it just looks like a hack job. Do a search for past posts this has been a heated debat on the "right way to do this swap". Some beleve since the hole was not factory then it should not be there. Dropping the gas tank is the way any service guide shows but can be a pita if you get a bad pump or don't do something right the first time. I say do what works best for you and the tools and abilitys you have.
Old 05-14-2005, 10:00 PM
Borsty's Avatar
Car: 89 Trans am
sound not too bad of an idea, any pics or info on that type of setup?
Old 05-14-2005, 10:24 PM
91blkta's Avatar
https://www.thirdgen.org/techbb2/sho...fuel+pump+door
here is one
https://www.thirdgen.org/techbb2/sho...r&pagenumber=3
here is the heated debat no pictures anymore
It can be done nicely some of the imports have them from stock I'll try to find a better example of a nicely made door.
Old 05-14-2005, 10:41 PM
91blkta's Avatar
here is a post of the right way to do
https://www.thirdgen.org/techbb2/sho...ight=fuel+pump
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: fuel pump swap
