No Spark
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
No Spark
I was driven my car and it died. Tried to restart it and nothing, checked the for spark and there was none. I have HEI Distrib, went and bought a new MODULE & ROTOR BUTTON. When I put the parts on and got the distributor cap back on it, still had no spark. Would the distrib cap cause that if not that is the only other thing that I could fihure that would be wrong. Would anything else cause the car to not have any spark? Any replies are help would be great.
1 Post
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
The pick-up coil, or the ignition coil. If you have a logic probe or a meter with a logic function check the ground side of the primary ignition for switching voltage. If you don't see that ground side switching then you would suspect either the pick-up coil or the ignition module. Since you have a new module you can rule that out. If you do see the ground side switching then I would suspect the ignition coil.
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
