Broken bolt inside cam retainer hole!
Car: 1991 Trans Am GTA
Engine: 350 tpi
Well I need serious help right now...i was putying the cam plate on the can and while tightening the 2 torx screws that hold the plate on one of them just snapped inside
Im really bumbed out does anybody know how I could possibly get this screw out of there?? Or if its even possiblr to get it out....any ideas would be great thanks.
Received 1,672 Likes
Re: Broken bolt inside cam retainer hole!
Sure; a bolt extractor.
Drill it out CAREFULLY, starting with a small bit, like a 1/16", after grinding or filing it flat and center-punching it. Use one of the SQUARE type of extractors, NOT the reverse-spiral ones.
The dealer carries new ones, you'll probably have to buy a bag of like 10 though. Or maybe you can get one at the junkyard. No "regular" bolt will do because it has to have such a low-profile head, unless you can find a "button head" bolt.
Engine: 350 tpi
But the messed up part is the back piece broke off in there
Engine: 350 tpi
that's what ill do ill let u guys know how it goes......
Engine: 350 tpi
Well thanks u guys the bolt actually came out with ease no problems thanks again.
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
84z96L31vortec
08-10-2015 08:27 PM
