Help adjusting to new valve covers.
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
Ok, so I got some new/used (new to me) valve covers. (they are the chrome ones with Chevrolet on them. My only issue is they each only have 1 hole a piece. But on the stock ones I have 3. driver side has 2, one for oil cap and one for PCV valve. the passenger has one which originally had the little hose hooked up to the stock air cleaner but I now have a open element so it's one of the small spectre air filter thingys.
My question is. What do I do? Do I not have the PCV valve connected or what? also they don't have the black rubber like things on inside edge of the holes. do I need to get new ones? Thank you for any and all help.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Help adjusting to new valve covers.
You can get grommets for it at a parts store. You'll have to forego the oil filler, and fill it through the PCV holes.
Car: 85 sport coupe
Engine: 355 sbc
I understand the grommet part but I don't understand the last part
Engine: 383 Carb
Transmission: 4L60
The factory covers have 3 holes: oil filler, PCV breather and PCV valve
The new ones have 2 holes: PCV breather and PCV valve
You won't have an oil filler anymore. Every time you want to put oil in it from now on, you'll have to pull out either the breather or the valve, and pour it through that hole.
Car: 85 sport coupe
Engine: 355 sbc
oh gotcha! thank you sir! You are a true gentleman and scholar!
Car: 85 sport coupe
Engine: 355 sbc
If you ever come by NC I'll take you to dinner lol
Hotrodboba400
12-10-2019 07:07 PM
dimented24x7
09-06-2015 03:51 PM
