Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Old 06-17-2013, 11:36 PM
  #101
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Re: Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Its on the left side.
Old 06-18-2013, 01:11 AM
  #102
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Lets make this easier. Driver side or passengerside.
I can take a picture for you tomorrow if youse like.
Old 06-18-2013, 08:17 AM
  #103
Car: 1991 red Z/28
driver side Yes I would love a pic of where the hose runs under and to the throttle body )
Old 06-18-2013, 10:46 AM
  #104
Sure. No problem. All that is underthere is a T connector. The middle tube on the connector fits over the TB nipple and the outer ends go to the canister and the EGR Solenoid. But no problem. When I get out of work, I'll post up a picture.
Old 06-18-2013, 10:59 AM
  #105
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Originally Posted by eseibel67
Second last one on your list, if you could please sir:
1987-1989 5.0L AND 5.7L TUNED PORT INJECTION
Yes this is my GTA
Old 06-18-2013, 11:05 AM
  #106
carattini's Avatar
Car: Pontiac 89 GTA
Here it is....
Thank you so much
Old 06-18-2013, 11:12 AM
  #107
Originally Posted by carattini
Thank you so much
Yessir!!
Old 06-22-2013, 02:18 AM
  #108
KayTeesFirebird's Avatar
Car: Firebird
Engine: Tuned Port Injection T.B.I
Transmission: 700RA Borg-Warner
Axle/Gears: Positioned Limited Slip
Do you have the vacuum diagram for a 87' 5.0 V8 fuel injected Firebird ?!
Old 06-22-2013, 10:25 AM
  #109
I think Camaro's and Firebirds had the same engines. With that said, the first page.
Old 06-23-2013, 12:47 AM
  #110
Car: Firebird
Yeah think everything is basically similar but yeah I got it it idles great just fluctuates from 700-800 RMP . Thank you though been hunting for I couldn't find it for the life of anyone lol .
Old 06-23-2013, 12:51 AM
  #111
Right on man.
Old 06-23-2013, 05:32 PM
  #112
Car: 1991 red Z/28
Any chance on taking that pic of the line that runs under the throttle body (and behind the alternator) over to the charcoal cannister?
Old 06-23-2013, 08:29 PM
  #113
Yup. Give me a couple of minutes. Sorry man. I forgot. I'll get them up right now.
Old 06-23-2013, 08:41 PM
  #114
Old 06-23-2013, 08:43 PM
  #115
Old 06-23-2013, 11:26 PM
  #116
Car: 1991 red Z/28
Thank you so much for taking them and your time. I didnt realize it went way back there to that. I thought it went just to the throttle body.
Old 06-24-2013, 12:07 AM
  #117
No problem man. That part that the far end of the hose connects to is called the EGR Solenoid.
Old 07-02-2013, 12:24 PM
  #118
magwired's Avatar
Car: 88 Camaro POJ
You have one for 88 camaro 5.7 w/ carb
Old 07-02-2013, 09:43 PM
  #119
  #120
Search on page 1
Old 07-02-2013, 10:17 PM
  #121
magwired's Avatar
Car: 88 Camaro POJ
Not in there chief
Old 07-02-2013, 10:25 PM
  #122
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Same as a 350
Old 07-02-2013, 10:29 PM
  #123
Yes it is. Look on post #28.
  #124
Last picture on #28.
Old 07-02-2013, 10:57 PM
  #125
magwired's Avatar
Car: 88 Camaro POJ
Ahh gotcha thanks
Old 07-02-2013, 10:59 PM
  #126
Ahh gotcha thanks
My fault. I should if notes the 5.0 is the same as a 5.7. But my bro TunedPerformance caught it.
Old 07-07-2013, 03:33 PM
  #127
Almac3's Avatar
I have a 1992 camaro Rs with a 305 engine nand a 4 speed trans. a vacuun line on the nrear of the carb has disconnected and I' not sure where to reconnect it and to what.
Old 07-07-2013, 04:46 PM
  #128
Go to page 1 and look for your diagram. Itll probably be marked as a 305 or 350.
  #129
Carb or TBI?
Old 07-07-2013, 05:24 PM
  #130
magwired's Avatar
Car: 88 Camaro POJ
Pcv on the valve cover
Old 08-02-2013, 06:17 PM
  #131
Ndb
Ndb's Avatar
On a 1992 5.7 tpi there is a vaccum diffuser that is suppose to connect to throttle body and then connects to two different places , do you know where the other two ends connect?
Old 08-03-2013, 12:42 PM
  #132
Diffuser? Do you have a picture?
Old 08-03-2013, 01:24 PM
  #133
Ndb
Ndb's Avatar
It was with the pieces when I got car and didn't know where it went,
A repair manual shows it but not what all it connects to
The side tees into throttle body then the little end heads to toward back of engine and bigger connection goes toward front but I do not know what they actually connect to . The manual show pic to disconnect it when removing throttle body, the vacuum diagrams don't even mention it
Old 08-03-2013, 03:22 PM
  #134
I think that's a check valve. The only thing the I have on my 86 IROC is a T, which connects to the EVAP, to the throttlebody, to the EGR solenoid.
Old 08-03-2013, 03:45 PM
  #135
Ndb
Ndb's Avatar
The book calls it a damping valve ,my car is a 1991 trams am GTA, 5.7 tpi.
Old 08-10-2013, 10:40 AM
  #136
petacrazy's Avatar
Car: 1992 camaro
Engine: 5.0
I just collected ALL vacuum lines from 82 - 92 TG F-Bodies!!!! If anyone needs one, drop a line requesting one (along with year, model, engine size, and tranny) and Ill post it up as soon as possible. Models covered with vacuum lines are:
1982-1984 2.5L TBI
1985-1986 2.5L TBI
1982 2.8L CARBURETED
1983 2.8L CARBURETED
1984 2.8L CARBURETED; EXCEPT CANADA
1984 2.8L CARBURETED; CANADA
1985 2.8L FUEL INJECTED
1986-1989 2.8L FUEL INJECTED
1990-1992 3.1L FUEL INJECTED
1982 5.0L CARBURETED
1983 5.0L CARBURETED
1984 5.0L CARBURETED; EXCEPT CANADA
1984 5.0L CARBURETED; CANADA
1985 5.0L CARBURETED; EXCEPT CANADA
1985 5.0L CARBURETED; CANADA
1986 5.0L CARBURETED; EXCEPT CANADA
1986 5.0L CARBURETED; CANADA
1987-1988 5.0L CARBURETED
5.0L CROSS-FIRE FUEL INJECTION
1988-1992 5.0L THROTTLE BODY INJECTION; MANUAL TRANSMISSION
1988-1992 5.0L THROTTLE BODY INJECTION; AUTO TRANS.
1985-1986 5.0L TUNED PORT INJECTION
1990-1992 5.0L AND 5.7L TUNED PORT INJECTION
1992 5.0 automatic get you get a chance. Thanks so much!!!!!
Old 08-10-2013, 10:41 AM
  #137
petacrazy's Avatar
Car: 1992 camaro
Engine: 5.0
1992 5.0 automatic. When you get a chance thanks!!
Old 08-10-2013, 11:33 AM
  #138
There are 3 diagrams for a 90. Everything I have is posted in page #1.
Old 09-07-2013, 09:23 AM
  #139
ejm3932's Avatar
Do you have a diagram for the vacuum line for the heater control valve in a 1990 IROC Z 5.7 liter?
Old 09-07-2013, 03:10 PM
  #140
I probably do. I have to look through my GM Service Manual and of through the digital service manual.
Old 09-07-2013, 03:37 PM
  #141
Engine: Lb9
Transmission: M20
The back manifold vacuum port on the passengers side plenum is the hvac vacuum. Vacuum goes to your mode selector in the dash and in heat mode vacuum goes to the heater control valve allowing the valve to open and coolant to flow through the heater core.
Old 09-07-2013, 06:56 PM
  #142
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Thanks. Very useful for my rebuild.
Old 09-07-2013, 07:13 PM
  #143
Old 11-12-2013, 09:04 AM
  #144
BlackJet's Avatar
Car: 1988 Formula 5.7
Nice find, still helping us in 2013.
Thanks for posting that
Old 02-12-2014, 12:28 PM
  #145
M Harris's Avatar
I need a diagram for a 1988 5.7 TPI. The set up was totally disassembled when I bought it.
Old 02-12-2014, 12:30 PM
  #146
Engine: Lb9
Transmission: M20
Look on the previous pages, its there !
Old 02-12-2014, 01:27 PM
  #147
rayount's Avatar
I am interested. I also would like a wiring diagram (I reviewed my manual, but not complete or accurate). Mine is a 1985 Firebird Trans Am, 5.0 TPI auto trans.
Just editing my post, saw that you posted them all here. Thanks!
Thanks,
Ron
Old 02-12-2014, 02:02 PM
  #148
Engine: Lb9
Transmission: M20
Thanks,
Ron
http://www.austinthirdgen.org/?pid=19
The 1226870 schematic can be found on chevythunder.com
Old 02-12-2014, 02:28 PM
  #149
rayount's Avatar
Dude - you rock! Thanks
Old 02-12-2014, 10:56 PM
  #150
Thanks Tuned Performance for updating. You the man!!!!
Quick Reply: Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
