MALICIOUS URL WARNING!! BEware
Old 09-23-2013, 11:01 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Two notices popped up today while using Third Gen.org !
MALICOUS URLS were blocked by my PC.
MEMBERS BEWARE !
I don't need that sort of BS from an "enthusiast site". if the moderators do not have an explanation, I am going to cancel my affiliation.
Old 09-23-2013, 05:39 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: MALICIOUS URL WARNING!! BEware
Im sure everyone will be devastated.
Most of the time these things are from something on the end-user's computer or from a random advertisement that goes through a third party and although these services are completely legitimate, every once in a while weird things happen and they're usually caught pretty quickly. There's also times the server itself gets hijacked by a virus. So don't assume that The Entity of TGO is after you.
But you can go on blaming the moderators or thirdgen.org if it makes you feel better.
Old 09-23-2013, 09:11 PM
LHernandezJr's Avatar
Old 09-23-2013, 09:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I just use Adblock Plus to filter out all ads which is where stuff like that comes from.
If your virus scanners do pick up malicious links, please notify any moderator of the offending link.
Old 09-24-2013, 07:51 AM
FRMULA88's Avatar
Car: 1988 Formula
I will, thanks. I never had an issue on TGO in the 12 years I have been a member so it was odd to see that.
but it seems this site runs much slower than it used to.
This machine has avast!
Old 09-24-2013, 07:52 AM
FRMULA88's Avatar
Car: 1988 Formula
NOPE, just you lover boy !
Old 09-24-2013, 08:05 AM
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1Aauto
Sponsored Vendors
11-23-2015 02:17 PM
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
1Aauto
Sponsored Vendors
08-26-2015 02:14 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
Quick Reply: MALICIOUS URL WARNING!! BEware
