Engine won't idle correctly
Car: 87 Iroc Z28
Engine: 350tpi
So my 87 Iroc 350tpi/automatic is acting odd. I can fire it up when it calms down will idle at about 1000rpm. After a drive of any amount of time it will idle at 2000k When put in park or neutral. And will stay there unless a quick touch on gas pedal. After that it will drop down to 1000 again, if you touch gas again it goes back 2 grand and stays there like before.
Not sure whats causing this. Also have a issue with starting. Some days it kicks right over other days it acts as if its carbed.
Car: 88GTA
Engine: 5.7TPI
Re: Engine won't idle correctly
Lots of info on here pertaining to this common issue.
For starters, check for codes, and then try this procedure "TO A TEE."
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
