Looking for old crane cam card.
Car: 1992 camaro rs
Engine: 383 stroker
crane doesn't make this cam anymore so it isn't on their website
HIT-284-2-nc
I've found other specs online but I'm looking for the install height for the valve springs.
HIT-284-2-nc
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: Looking for old crane cam card.
Call Crane. I had questions about my Comp Cam and they had all the answers. Great customer service IMO
Ask and you shall receive. Can't believe I found this for you (usually old part numbers are like deciphering the Rosetta Stone), but here it is.....
https://books.google.com/books?id=Mr...4-2-nc&f=false
Car: 1988 Camaro
Yes the cam don't really care what the spring's installed height is or has anything to do with installed height.
Your installed height is set by spring pressure, valve length, locks, retainers, shims, coil bind height of your springs, etc.
The common sbc spec is 1.700" but that all depends on your setup, and springs.. Taller installed height will lessen the spring pressure, where shorter installed height will add more spring pressure.
Hotrodboba400
12-10-2019 07:07 PM
