Figuring out my car's fuel delivery origin..
Car: 87' Firebird Formula
Hey everybody.. the while i've had my 87' firebird formula, it has never ran like my previous 3rd gens. The previous owner said that a 350 had been "swapped" into it so I assumed it was a 305 before that. It has some shorty headers with the AIR tubes, a street dominator intake, and HEI coil topped distributor, and a regular old quadrajet. I have noticed an abundance of wiring harness and unplugged connectors everywhere and it is currently carbureted. Part of the harness even goes into the passenger fender like my old TBI car harness did. Also, sometimes while driving, it jerks really bad and won't go over 25mph (kind of like the limp mode that i've read about). I am curious as to if it was maybe TBI or TPI before the swap. Or maybe it had a computer controlled carb. Is there anyway of knowing its original fuel delivery?
Re: Figuring out my car's fuel delivery origin..
should I have put this in the "swap" section? I just need to know how to find out what my car's original fuel delivery type was so I know what direction to take for fixing my car. If it WAS originally TBI, I want to go back to TBI. Same as TPI or carb. Just want my car to run better.
If you search out "Decode VIN" , you will come up with threads that will tell you how to figure out what engine/fuel induction came with your car . One of the VIN characters will correspond to it . It will be something roughly like "Engine code S = LB9 / 305TPI" or other some such (those are for example only and are NOT actual codes , just something to illustrate the point)
Oh , and the best place for this question would have been the "History/Originality" section of the forum . I wish you the best of luck with your restoration
AkDrifted
08-17-2015 07:45 PM
db057
08-11-2015 10:11 PM
